Old 10-14-2004, 10:54 AM
moldy moldy is offline
liter size
how does the liter size of a engine hender horsepower.
Old 10-14-2004, 12:18 PM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
Liters measurement of an engine dosen't hinder horsepower its just a different measurement of the engine total displacement.
6 Liters = 366 Cubic Centimeters(CID) an vise versa
I disregard my perceived image in the persuit of knowledge.
Old 10-14-2004, 02:01 PM
RandomTask's Avatar
RandomTask RandomTask is offline
Banned
Re: liter size
the liter size is the volume of the motor. Essentially the bigger the volume, the more power you can harness. Other factors contribute to HP mainly the efficiency of the motor.
Old 10-15-2004, 10:05 AM
clawhammer's Avatar
clawhammer clawhammer is offline
Re: liter size
The engine size is just the change between when the cylinder is open, and fuel and air is added and when it is fully compressed. Multiply that by the number of cylinders and you have to size of the engine
Old 10-15-2004, 11:08 AM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: liter size
366 cubic centimeters? 366 cubic inches. just a little corection so no one gets confused since 366cm^3 = 0.366litres. basicly the larger the engines the more power it is able to make because more air and fule can be stuffed into it. a 2.0l 4cylender turbocharged runnin 14.7psi of boost should have ~ power of a 4.0l NA 4cyl engine at sea level. in theory anyway. many other factors such as mechanical timing, fule, compression ratio, spark advance, cam, friction from the turbo, friction from assesories (A/C compressor, power brakes, power steering, altinator) and many other things will effect net and gross power output.
ps
this has been covered many a time since ive been here. please dont ask old questions. try using the form seach feature first. thanks.
Old 10-15-2004, 11:12 AM
yea CID makes sence lol brain fart :P
