Old 10-14-2004, 09:52 AM
andrewespo's Avatar
andrewespo andrewespo is offline
Question Question?
What special tool do you need to get the fuel filter off?
Thx
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
Old 10-14-2004, 07:52 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
pull the white clips out and it comes off.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 10-14-2004, 08:21 PM
andrewespo's Avatar
Re: Question?
Oh....
Old 10-14-2004, 11:09 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
i do it with a small screwdriver. be warned, fuel will spray, and the clips are annoying to get back in. when i did mine i relieved system pressure like i was supposed to, but was still literally soaked in gasoline by the time the filter was out from under the car. can you say quick shirt change?
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 10-14-2004, 11:44 PM
lntegraLover lntegraLover is offline
Banned
Re: Question?
what u need to do is zip tie the fuel line as well as the return fuel line completely shut. then u wont have to change ur shurt like the stangnutnoob
Old 10-14-2004, 11:56 PM
-Camel-'s Avatar
-Camel- -Camel- is offline
Banned
Re: Question?
another thing you can do is put a shop vacum in your fuel tank to remove all the gas. This will stop the spraying that the other guy was worrying about, silly n00b.
Old 10-14-2004, 11:58 PM
Banned
Re: Question?
or simply run ur car until u run out of gas and as soon as u run out, replace that fuel filter. it might take u a while to start your car again, but that is something your used to by now, being a stang owner.
Old 10-15-2004, 12:03 AM
-Camel-'s Avatar
Banned
Re: Question?
starting a car that has run out of fuel is simply simply fill your tank to the rim. then take a common boike pump and seal it into your tank. you might want to use apoxy. Then you will need to pump that mother up until you cant pump it anymore. turn the engine over and hold a butane liger in place of one of the spark plugs. This is very efficent and cheap.
Old 10-15-2004, 12:44 AM
Banned
Re: Question?
excellent point camel. even children can do this one
Old 10-15-2004, 12:57 AM
Will someone please ban these immature idiots!!!
Old 10-15-2004, 08:13 AM
andrewespo's Avatar
Re: Question?
