Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 10-14-2004, 09:08 AM
pablitor9 pablitor9 is offline
Broken Needle
I tried to install indiglos on my 95 civic dx and I broke a needle does anyone know how to fix it, or where to buy one. If I do buy do I have to buy the whole gauge console, and if i do can the mile reading thing be exchanged to the new one. Any suggestions?
Old 10-15-2004, 02:34 PM
prototype80's Avatar
prototype80 prototype80 is offline
Send a message via AIM to prototype80 Send a message via MSN to prototype80 Send a message via Yahoo to prototype80
Re: Broken Needle
ok i had this problem with my 99 civic. i had to source the whole new cluster at a local junk yard but it is possible to remove needles and stuff from an existing cluster and just transfer them. although the screws are a pain in the butt and you risk breaking the needles agin trying to screw them in. i would suggest buying a need guage cluster from a local junk yard and using a eye glass screw driver to advance the odometer to where you need it. i had to go through these woes also it may be a little costly but it'll save you time and frustration. just as a quick question which needle did you break while installing . i broke the fuel and water temp ones and found out you just point the needles up to slide the guages on.good luck
Old 10-15-2004, 08:41 PM
Re: Broken Needle
Hi thanks for the reply. The broke the fuel needle. Buying the whole cluster is not the problem the thing is the different milage on the odometer. If I get a new one wouldn't it brake if I try to advance the odometer? that's my main concern.
Old 10-16-2004, 12:36 AM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
Re: Broken Needle
you jsut point them straight up? that seems soooo easy
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 10-17-2004, 09:21 PM
Re: Broken Needle
Now I know after I broke it Thanks for the advice
Old 10-17-2004, 09:40 PM
Re: Broken Needle
all i did was spin the odometer with a eye glass repair kit screw driver. it didnt break and everything seemed to work fine and dandy after i did it. it may take a little pressure but it should work
Old 12-26-2004, 09:22 PM
FinalAeon FinalAeon is offline
hey man i've had the same problem as u all... lucky 4 u i did my research... if u've broken either the temp gauge, tach, or fuel gauge... u DO NOT have to replace your whole cluster! i have a VERy detailed tutorial as how to go about replacing a single oem gauge...
tutorial: http://www.rideatl.com/modules.php?n...viewtopic&t=16
it says for accords but it's the same for most hondas, like civics and preludes...
i broke my temp gauge and replaced it for $26 total :P
Old 01-16-2005, 08:34 AM
98civiccx's Avatar
98civiccx 98civiccx is offline
Smile Re: Re: Broken Needle
Originally Posted by FinalAeon
tutorial: http://www.rideatl.com/modules.php?...=viewtopic&t=16
Posted by prototype80 - 10-17-2004 at 11:40 PM
wicked link...all i need to know now is where to get a replacement guage...wreckers?, dealer?, aftermarket shop? did you get a new or used one? if it makes a difference i broke my temp guage...
"In Canada, we reserve beers with less than 5% alcohol for children and the elderly!"
Old 01-16-2005, 11:25 AM
i searched for mine on ebay... i got a 97 accord cluster for an automatic... i also needed the temp gauge... so i bought a cluster with a broken speedometer/odometer and a broken fuel gauge... the only thing that worked was the tach and the temp gauge so i saved a lot of money there... i got it for $26 shipped
glad to be of service
Old 01-18-2005, 07:07 PM
98civiccx's Avatar
Thumbs up Re: Re: Re: Broken Needle
Thanks FinalAeon, that should be alot of help...
Old 01-18-2005, 07:51 PM
bingisSD's Avatar
bingisSD bingisSD is offline
Send a message via AIM to bingisSD
hell when i bought my first hatchback it had 189,000 miles on it, but then i broke the calibration putting in my indiglos and got a new cluster with only 104k miles, i sold that car as if it really only had 104k miles
if they check the carfax report they might figure it out, except that I did all the work myself so nobody had my m ileage documented.
AND on your pink slip you have the option of checking a box in the middle of the page that says 'odometer reading is not actual mileage/innacurate'. at least in california we do
www.cardomain.com/id/bingissd
http://www.automotiveforums.com/vbulletin/showthread.php?p=2660831#post2660831 <MEET IN DAYGO
Old 01-19-2005, 05:02 PM
riccimangan riccimangan is offline
Re: Broken Needle
I bet you all used a flat head screwdriver to remove the needles huh? me to and i fu*ked it up aswell. i find the best way to do it is to put a piece of string around the needle and and pull it straight of evenly. as long as you keep the needle straight the it wont break,.,,. works every time,.,.,.,.,
