Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 10-14-2004, 08:58 AM
higherlevel higherlevel is offline
spark plugs
86 n/a, what has to be removed to change spark plugs. Does anyone have any printable instructions?
Old 10-14-2004, 01:16 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: spark plugs
nothing i don't think... all you need is an extension and a u-joint and you're good to go, the front left one is a little tough to get at, you need to unhook some connectors to get at it.. just be careful and make sure you don't break any of them (1st hand experience on that one) having a spark plug socket is really handy with this car, as there's absolutely no way you're going to get anything else down there to pull the plug out
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 10-14-2004, 06:19 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: spark plugs
always use a spark plug socket. much much much easier on you.
-Jared
ZedEx Crew Member #2
Old 10-14-2004, 07:47 PM
Zgringo Zgringo is offline
And blow air around the plugs before you remove them so shit don't get inside your engine.
Old 10-15-2004, 01:45 PM
Hodo Hodo is offline
Re: spark plugs
and make sure you torque them in there right, too much and you crack them, to little and they will blow right out. Both cases are BAD.
