Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 10-14-2004, 09:49 AM
burly94gt burly94gt is offline
cant make up my mind!
OK...i recently puchased a pair of TFS tw heads that have been milled to 58cc's and have a fresh valve job, and also slight port work (clean up/polish). keep in mind my car is full injected and everyday driven. ive been lookin at trick flows intakes, and i cant make up my mind on either getting the track heat or the r-series. will i make more power w/ the r series, that is if i purchase one of ed curtis' custom ground cams to match either intake? i will appreciate any and all feedback!
God said RWD, and all the little torque lovers of the world said, AMEN!!
Old 10-15-2004, 02:05 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Unless you got major power, like 500 plus, a trick flow r will only decrease your performance. A track heat is plenty and works well with the twisted wedge heads.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 10-15-2004, 09:21 AM
Re: cant make up my mind!
hey racer20, can you give me a estimate at what i might put out w/ my twisted wedge heads,track heat intake, custom ground cam, 373's, t-5, and all the other minor bold on's....i know estimates are vague but alot of what you have in your sig besides the stroker is close to what i will be running...
Old 10-15-2004, 01:21 PM
Re: Re: cant make up my mind!
Properly tweeced, I'd say 300 rwhp is very achievable. You may want to do some mild exhaust porting to the heads as well. I also learned something over the weekend that the twisted wedge heads love timing. My friend was running 93 octane with 19-20 degrees advance, getting excellent times the other day.
