Old 10-14-2004, 06:34 AM
Lotus49 Lotus49 is offline
Send a message via Yahoo to Lotus49
Changine performance
This is an odd one for me. I had my car dyno'd. Its a 1994 z28 with 180k on it. Valve covers have never been off. It gave 180rwhp the 1st pull 250wrhp the 2nd pull and 225 the 3rd pull. Ive noticed on the road that, even though the temp is the same, the acceleration varies from 5.5 all the up to past 7 seconds 0-60. Any idea on this? Also, My friend has removed the spring on the thermostat, I plugged my snap on scanner into his OBD port and the car is running on average 140-160*F. Is this ok to do for my car too?
Old 10-14-2004, 06:44 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Changine performance
Usually they run a little hotter than that, Did you have your fans reprogrammed Also do you have a Auto or 6 speed
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-14-2004, 01:43 PM
LT1MAN LT1MAN is offline
Banned
is the z28 stock layin down 250? no mods?
Old 10-14-2004, 03:45 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Not a good idea.. doesnt sit well with a/f and emissions
1991 Camaro Z28
Old 10-14-2004, 10:31 PM
its automatic... and to be honest i did the same thing with the thermostat.. and its actually running alot more colder, and powerful.
Old 10-14-2004, 11:04 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
i dont know why you would pull such different numbers three times...
*Better power-to-weight ratio than a C6 corvette*
Old 10-14-2004, 11:58 PM
FormulaLT1's Avatar
Fight the powwa!!!
If you where having a ignition, Fuel injector or pressure or compression(most likely not the case) or Vacuum probelm. The results could be drastically different each run.
Old 10-15-2004, 01:00 AM
'97SLVRBullet's Avatar
'97SLVRBullet '97SLVRBullet is offline
Send a message via AIM to '97SLVRBullet
Re: Re: Changine performance
I agree, these cars run best between 160 and 180. 140 is way to low.
97 Z28
C.A.I. Edelbrock shorties,all free mods,Borla's,MSD,LT4 timingchain, 1.6r/r,LT4 cam, NGK,p&p heads,ported maf ,52mmTB adj fuelpressure reg.,373's,pcm tune by pcmforless, all poly bushings,spohn t/a, s/t brace, etc. What I don't have..no egr no air pump and no cats
Well dip me in chocolate and
throw me to the lesbians!!!!!
