Old 10-14-2004, 03:25 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Stumped???
Ok a friend of mine has a 89 si hatch with a b18a in it and two day's ago he was driving along and he said he heard a pop an his car died. So he checks the usual timing belt and tried to jump it and it would crank off the jump.
I looked at it briefly in the dark tonite and timing belt was still tight, all belts and hoses were there. So I tell him to check the codes, he's getting a MAP sensor code and TDC code and a Crank angle sensor code anyone have a similar problem?
Im stumped maybe an electrical problem fry the wires? I dont know why he would have heard a pop? It wont even crank now, internally fuck something up? I have no clue never heard or had any similar symptoms like this before.
Whats weird is this happend the same day he wrecked his other car two years ago on the same road and around the same time.
Any help is appreciated by me and my friend.
2002 Acura TL Type S
1991 Honda Crx Si
Old 10-14-2004, 03:35 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Stumped???
what does it do when he trys to start? will it turn over?
Old 10-14-2004, 09:01 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: Stumped???
Probably blew the main fuse.
Old 10-14-2004, 09:07 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: Stumped???
I'd check the rotor.
Old 10-14-2004, 09:39 AM
Re: Stumped???
it does not turn over it does nothing.
fuel pump comes on. gauge cluster lights up there is battery power.
I was thinking something with the dizzy but wondered how that would affect the map sensor unless it's two different problems.
thank's for the suggestions
1991 Honda Crx Si
Old 10-14-2004, 10:38 AM
91civicDXdude's Avatar
Re: Stumped???
if it wont turn over and the starter is getting power, its something a little bigger than a distributor problem
Old 10-14-2004, 11:54 AM
CRXsiZCpa's Avatar
CRXsiZCpa CRXsiZCpa is offline
Re: Stumped???
check the compression
Old 10-14-2004, 01:07 PM
bigwally9876's Avatar
bigwally9876 bigwally9876 is offline
Send a message via Yahoo to bigwally9876
Re: Stumped???
my car did the same to me one night my rotor was just loose and it was giving me the same code...good luck
Old 10-14-2004, 02:05 PM
Hybrid1990crx's Avatar
Re: Stumped???
Yeah, I agree with Mellowboy. Check the rotor.....even though if the rotor did fall off i'd think it would still turn over.
Old 10-14-2004, 02:44 PM
Forunn Daberator
Re: Stumped???
The rotor wont effect it not turning over. Its an 89 so he cant push start it (unless hes removed the clutch safty switch). I'd pull the starter off and test it.
Old 10-14-2004, 03:36 PM
Re: Re: Stumped???
WTF are you talking about? I've pop started my car before. Like when my coil was starting to go bad in my 90 crx i did it all the time, and I also did it in my 89 to get my check engine light to go away because i was pissing me off at night time.
Old 10-14-2004, 03:40 PM
Forunn Daberator
Re: Stumped???
You cant push start a car that has a clutch safty on it, because the clutch has to be pressed in for it to start.
Old 10-14-2004, 03:41 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
maybe something internally snapped... like a cam or something, the timing belt coulda slipped, when mine did it stayed tight
Old 10-14-2004, 04:12 PM
Re: Re: Stumped???
Well I have. Multiple times.
Old 10-14-2004, 04:19 PM
Forunn Daberator
Re: Stumped???
can you start your car without pushing the clutch in?
