Old 10-13-2004, 10:54 PM
wellhung2004's Avatar
wellhung2004 wellhung2004 is offline
Send a message via AIM to wellhung2004
head swap
can the D16 head out of a 92-96 civic, swap on to the d16YB? if so, what all do i need. both are SOHC VTEC.
http://store3.yimg.com/I/jspec_1793_10301627
Old 10-13-2004, 11:13 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: head swap
The '92-'95 Civic EX SOHC VTEC motor is the D16Z6. The D16Y8 came in the '96-'00 Civic EX's. They're both essentially the exact same motor. The D16Z6 is OBD1 and the D16Y8 motor is OBD2. That's really the only difference. They both have the same HP and torque.
Probably all you'd need is the ECU from the D16Z6 and to find a way to covert to ODB1. Honestly, I say stick to what you have. They're the same thing.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 10-14-2004, 12:56 AM
Re: head swap
no, im swapping because the D16Z6 head has been ported and polished. so what would you stick with now?
Old 10-14-2004, 09:10 AM
sageuvagony's Avatar
sageuvagony sageuvagony is offline
Send a message via AIM to sageuvagony Send a message via Yahoo to sageuvagony
what what you have now
1997 Integra GSR and 1992 Civic LX
Old 10-14-2004, 04:41 PM
Re: head swap
um, ok, i want to know if a ported and polished head from a D16Z6 will fit in the place of a D16Y8 head.
Old 10-14-2004, 04:50 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: head swap
yes, but no point. port and polish won't gain you that much unless you have some other high hp mods.
Empty Pockets Racing Member #1
Old 10-15-2004, 03:47 PM
ok, thanks
Old 10-16-2004, 10:13 AM
ok, thanks
Old 10-18-2004, 03:28 AM
west nile west nile is offline
Re: head swap
Originally Posted by sageuvagony
ok, thanks
actually there is a difference between the d16z and the d16y8. the d16z is a higher flowing head and has less restrictions for fuel economy, and if your head is ported and polished even better. For d series info, go to d-series.org, you'll get a lot of info there.
