Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 10-13-2004, 09:12 PM
integrapimpin integrapimpin is offline
Question hydraulic to cable
Hey, I have a 93 integra and recently the transmission went out. I am looking to the b16 transmissions for their low gearing, specifically from 2000 civic si. The problem is it has a hydraulic transmission and mine is a cable. I haven't found anything on hasport for my car it's all 94+ integra. Does anyone have any suggestions?
Old 10-13-2004, 09:30 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
why dont you call them up and ask them, you probably could use the rear mount and hydro adapter for the 88-91 civic kit they have
Team Lonely Drivers
Old 10-14-2004, 12:20 AM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: hydraulic to cable
with the old school hondas (first gen ones from the 70's) guys often swap in the 1.8 accord engine, with the 80/81 models they have a hydro clutch and the way around that is to simply cut off the hydro mechanism and weld on the cable arm. with those trannys there is a place to mount the upper part of the cable support because it's also a mounting location for a removal hook but i have no idea if that will work in your situation
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 10-14-2004, 02:43 AM
does anyone know if I would be able to use all of my stock shift linkage on a newer transmission. Is all the shift linkage from the b series transaxles the same???
Old 10-14-2004, 09:16 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Yes you can use the stock shift linkage. I'm not too sure about the axles but i think i'd get the 94 and up integra axles , del sol vtec axles or '99-'00 civic si axles.
Old 10-14-2004, 09:58 PM
Thumbs up
hey thanks dudes!
