Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 10-13-2004, 08:49 PM
el es's Avatar
el es el es is offline
need some specs please
A graciuous good day to you all,
I would greatly appreciate it if you folks might be able to help me with collecting some data for an 00 V6 Sport.
I am searching for the following to help build a profile for the Speed Tracer tool from AutoEgninuity:
Weight ( I think wet weight is what they would be looking for )
Gear ratio
Drag Coefficient
Friontal Area (in sq ft)
Tire circumference for 17 in tire
Gar Ratio Variable
-Working Gear x.xxx:1
-REar End Ratio x.xxx:1
This tool came free with their scan tool whic I recently purchased and am would like to see this thing in action. Although I am a staunch DIYer I seldomly delve in to the realm of this tye of information and would even know where to begin. But I will look in my owners manual tomorrow becasue I do RTFM.
TIA
eL eS
Stand by for heavy rolls as the ship comes about!
Photo gallery of Ye ol' Black Pearl
Old 10-14-2004, 08:43 AM
CGGorman's Avatar
CGGorman CGGorman is offline
Re: need some specs please
'00 LS6 Getrag data:
Engine - 3.0L (2967cc) Aluminum DOHC, 4V
BorexStroke - 89.0x79.5
Compression - 10.5
Gear ratios, 1st through 5th, reverse- 4.23/2.52/1.66/1.22/1.00/4.14
Rear axle ratio - Varies by date (3.58, 3.31, or 3.07) Check tag on pumpkin.
Curb weight - 3572 lbs
Length x Width x Height (in) - 193.9x73.2x56.1
That's all I've got, Noah. You should be able to find tire dia on the tech sheet at the website for your tires. Frontal area might have to be a physical measurement unless heightxwidth will work. Drag Coef. might be out there in a test somewhere... I didn't dig real deep since I knew where this data was. Don't know what gear ratio variable is...
Chris Gorman -LLSOC Forum Moderator-
2000 LS8 sport (lowered 2", LLSOC Intake, Magnaflow catback, tint, more..)
