Go Back   Automotive Forums Car Chat > Ford > Excursion
Old 10-13-2004, 08:28 PM
duneswest duneswest is offline
#6 fuse keeps blowing on 2000 Excursion
#6 fuse runs overhead computer, turn signals, rear a/c and back up lights. I replaced it with 15 amp fuse and after a few days it blows again. There is no rhyme or reason when it blows. You can run signal, rear a/c all day long and it won't blow. Then all of a sudden it goes out. Sometimes when the a/c, back up lights and signals are off.
The manual says a 15 amp is the proper fuse. Could it be they spec out a fuse too low in amps?
Any suggestions?
Old 10-15-2004, 12:37 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: #6 fuse keeps blowing on 2000 Excursion
do you have signal mirrors?
-=-=-DANE-=-=-
Old 10-17-2004, 04:21 PM
No signal mirrors.
It seem the problem started after we had the passenger side power window replaced due to a break in. This is the window on the middle seat. The window was changed out and the fuse was blown after we got the car back. I thought it was something simple like a fuse so I did not take it back to the shop. But it obviously is more than a bad fuse.
Old 07-24-2012, 02:18 PM
paulshort67 paulshort67 is offline
Did you ever find out what the problem was with the fuse? in your excursion the number 6 fuse
Old 07-24-2012, 08:39 PM
danielsatur danielsatur is offline
How doe's the window work?
Even though other circuits are not being used, the control module + sensors demand power.
If there's 3- circuits to a fuse, try isolating 1 or 2 of the circuits out of loop by a disconnect!
12volts/15 amp fuse = .8 ohms
Old 08-06-2012, 02:43 PM
kklgpadgett kklgpadgett is offline
Sounds like a short in wiring. Pull panel on the door the window was replaced. also follow the wire by wire color to the fuse and disconet on on end check with tester.
