Old 10-13-2004, 07:28 PM
bravesbend bravesbend is offline
2000 alero will not start
2000 alero will not start. ran fine last night, this am would not start. I have spark and fuel. my security light sometimes stays on when key is on the on postion, and sometimes it goes off. I have switched fuel relays no help. does anyone have a idea?? If not it goes to the shop and I drive my 69 mustang to work. help please
Old 10-13-2004, 11:27 PM
mhlandry mhlandry is offline
If you have spark and fuel, you should have combustion, but you never know with these cars. When mine didnt start it was because of a bad fuel pump. Sometimes a bad engine coil caused it not to get a spark on other occasions. But this probably doesn't help you any because you sdaid you had fuel and spark...
Old 10-14-2004, 12:25 PM
sp3edr4cer sp3edr4cer is offline
Re: 2000 alero will not start
but a bad spark plug or coil may be providing spark just not a strong enough spark
Old 10-14-2004, 01:38 PM
faleigh faleigh is offline
Re: Re: 2000 alero will not start
mine did the same thing the other day, the positive post broke away from the battery. loosen your cables from the battery, then check your post. yours may have done the same. these batteries have a bad rap.
Old 10-15-2004, 04:10 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
if your security light came on, turn the key to the on position and leave it on for about 10 minutes. This will allow your pass-key system to re-learn the key and the car should start. Also, clean the metal contacts in the chip in the key with a pencil eraser to get any oils and dirt off it so it will read proper resistance.
