Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 10-13-2004, 07:26 PM
ll1480 ll1480 is offline
Message Center Problems
I have a 2001 Chevy Impala. The alternator was replaced last week. The battery has been checked and is OK. However, the following Message Center codes continue to light up first with "Security;" next with "Battery" along with 4 chimes; and then "Service Engine Soon." I have had the car checked twice this week, but nothing can be located. The messages generally light after about 10 miles. Any ideas/suggestions?
Old 10-14-2004, 08:30 PM
bermis519 bermis519 is offline
Send a message via AIM to bermis519 Send a message via MSN to bermis519 Send a message via Yahoo to bermis519
Re: Message Center Problems
did you have the codes erased? Thats the only thing i can think of..i don't know if the car stores them and keeps flashing them until they are erased....i don't know if disconnecting the battery would erase it...not sure...
mike
Old 07-07-2005, 12:42 PM
Andy2680 Andy2680 is offline
Re: Re: Message Center Problems
I called a service center and they said the Security light is obviously malfunctioning. It has to do with the anti-theft system in the car.
Old 07-07-2005, 08:54 PM
MCO_Death MCO_Death is offline
Send a message via AIM to MCO_Death Send a message via MSN to MCO_Death Send a message via Yahoo to MCO_Death
Re: Re: Re: Message Center Problems
I've seen my security light - light up once or twice in all the time i've had my car. I havn't a clue what good it even does, or how it works as a Anti-theft system. Anyone know exactly?
Old 07-10-2005, 12:10 AM
system_wired system_wired is offline
Re: Re: Re: Re: Message Center Problems
I believe what occurs is when you turn the key it sends a signal to where exactly I can't remember. The anti theft looks for that signal and if its there the car operates normally. If the signal isn't detected then the anti theft system thinks the car was started without the key (hot wired) and cuts off the fuel to the engine. When that happens the car can drive for something like a block tops before it craps out.
As for the anti theft light mine started comming on intermitently last year and eventually just stayed on all the time. When I went to the dealer they ran there tests and looked over all the wiring but couldn't find a problem. They determined that the BCM Body control module which sends all the signals to the message center was sending a false signal and would need to be replaced at a cost of $1200.00cdn plus programming. I passed on that since the light doesn't chime; I simply put a thick black piece paper over the message center and bam problem solved and 1200 bucks saved.
Old 07-10-2005, 07:53 AM
MoNsTeR`ImPaLa MoNsTeR`ImPaLa is offline
if your security light is comming on while driving you might need a new ignition switch if you are going to chase the problem i would start there since it is the cheapest fix
