Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-13-2004, 07:11 PM
steveabn82 steveabn82 is offline
Unhappy 94 CV will not shift into OD
My 94 Crown Vic will not shift into Overdrive.i can hit the OD button and drive fine with it out of OD but no OD . Any ideas ????
Old 10-14-2004, 12:52 AM
ModMech's Avatar
ModMech ModMech is offline
Re: 94 CV will not shift into OD
Does it drive when on "OD" after it shifts up from 3rd, or does it just rev up?
Old 10-14-2004, 07:58 AM
Angry
It revs up
Old 10-14-2004, 09:17 AM
ModMech's Avatar
Your OD band is toast.
Unfortuneately, it's time for a new trans. You can lock-out OD and drive it for quite a long time however.
Old 10-14-2004, 09:48 AM
Talking
By locking it out you mean keep the OD off by means of the switch???
The biggest thing I am losing is the gas mileage since it does have OD anymore Correct ?
Howver I should not complain the car has 255,000 miles the engine still runs real well and the cars does everything else very well.
Old 10-14-2004, 12:34 PM
ModMech's Avatar
Right, push the TCC switch after you start the car each time, and you will only hurt you fuel consumption rating.
Beware of "rebuilt" transmissions to. VERY VERY few places, even the national brands do even a decent job. If you decide to replace it, I suggest a Factory Ford reman.
Old 10-14-2004, 12:37 PM
Thumbs up
Thanks for your help.I will have to drive a while until I have enough pennies saved for the tranny, even at its mileage it sure runs GOOD. thanks again.
Old 11-05-2004, 06:54 PM
NineD6crownvicPI NineD6crownvicPI is offline
My 96 crown Vic trans won't even make it over 35 MPH its stuck on stupid, it won't make it out of 2nd gear. it takes off fine shifts to 2nd fine wont make it to 3 just revs higher and higer. . . HELP!
