Old 10-13-2004, 06:48 PM
WordLife_ WordLife_ is offline
Stealth R/t Engine Trouble
Hello Guys..
i own a 92 Stealth R/t and i woke up today to find something weird with the car...when i start the car...there is a very very strong noise coming out from the engine....its like the same noise of a truck when its parked..!!
However guys when i step on the gas pedal and drive away the noise stops....when i slow down and come to a full stop it comes back again...so its like when i drive...its fine...but when i stop it turns into that truck noise....i checked under the hood...everything is fine..the noise is not coming from the main engine...its coming from the builts area...and there is no CHECK ENGINE light in the dash..!!
I asked for help, some told me throw the whole engine away..its done for good...some said it needed a new engine head...and some said its the first time they hear of such a thing...!!
HELP..!!
thanks
Old 10-13-2004, 08:25 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Stealth R/t Engine Trouble
could you be a little more specific? what does the noise sound like? what the heck is the 'builts area'? and 'main engine'....??? there's only one engine, its either coming from the engine or not. perhaps, what part, area, of the engine is it coming from? does it sound like a ticking noise?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-13-2004, 09:38 PM
What i meant its coming from the further most right of the engine, where you can see all the builts running..!!
and as for the noise....i remember it used to be a ticking noise when i first started the car but it used to go away after the car is on for awhile...now the same noise exists but it doesnt go away after the car has been on for awhile...and yes i can say its probably a ticking noise..!! or at least close to that....!!
Old 10-13-2004, 10:28 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
linkbckr, be easy on him just because he doesnt know very much about cars doesnt mean you have to give him crap.
Wordlife, are you talking about the belts? (builts??) It its a ticking noise check that your oil isnt low. Maybe change the oil depending on how many miles have gone by.
Old 10-13-2004, 10:41 PM
baghel baghel is offline
hey..im wordlife's friend n i wuz with him when it happened....the noise is coming from the right hand side of the engine...i believe its where the timing belt is...and the noise is like tick tick tick .... its kinda close to a diesel engine's noise...thats as close as i can get to describing it...any questions ?
Old 10-13-2004, 10:44 PM
Linebckr49's Avatar
Talskin, i wasn't givin him crap, sorry if it sounded like i was, didn't mean for it to come across like that. I was just honeslty taken aback trying to think of what builts were, but belts seems like a good guess.
93 3000GT base
Old 10-13-2004, 10:56 PM
okay so can anyone help now with the details that ive given ?
Old 10-14-2004, 01:05 AM
Did you check your oil. If its low top it off and report back.
Old 10-14-2004, 01:08 AM
oil was changed on 149 clicks..now its on 1502xx....oil level is pretty normal !!
any other scenarios ?
Old 10-14-2004, 01:10 AM
btw...car duznt smoke..or smell bad or anything..
acceleration is almost as good as it was before...nth have changed really..its just that noise that tears my heart apart when i hear it....disappears when accelerating...goes crazy when back to idle...makes me feel bad
Old 10-14-2004, 10:10 AM
I took it to the dealership...
the timer needs to be changed, the valves, the head of the engine needs to be machined....its all gona cost me around 2200 canadian dollars...which is alotta money...but hey..i have no other choice..!!
REASON IS: change the timer chain every 100,000 Km's...or u will end up having the same problem..
good luck everyone
