Old 10-13-2004, 06:09 PM
Chev702 Chev702 is offline
Lightbulb 90 Lumina Coil Pack
Hello, Can Somebody Tell Me What Is Wrong With My 90 Lumina?? The First Coil Pack Is Dead. I Have Juice To The 2nd And 3rd Coil Packs. I Just Replaced Them all With New Ones. I Am In A Process Of Elimanation. I Have Replace The EGR,Wires,Plugs And Now Coil Packs But I Found Out The 1st Coil Pack Is Dead So I Think That Is My Trouble In Fact I Can Pull The 2 Wires Off And She Runs The Same As Normal. So I Am Running A 4 Clinder With a 6 Clinder Engine She Goes Down The Road But I Have No Snap. About Know About How To Test The Electric Connectors That Goes Into The Coil To See If It Has Juice??
Old 10-13-2004, 07:04 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 90 Lumina Coil Pack
Module. Test the ignition module.
cadgear's Avatar
cadgear cadgear is offline
I bet the ICM is bad, if you replaced the 1-4 coil pack and it still doesn't fire. Try that next.
Old 10-14-2004, 12:33 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Jeff and Cad, you've got a bad ignition control module.
Old 10-14-2004, 05:21 PM
Smile
I Hope I Don't Sound Too Stupid As I Am A Car Mechanic Of The Old School Stuff I Am Worthless With The New Time Stuff. But Now That We Know I What The Problem Is Where Do I Find The Electric Control Module?? Is That What The Coil Packs Plug Into?? And If So How Do You Get That Off??
Old 10-14-2004, 07:46 PM
cadgear's Avatar
It should be what the coil packs plug into. It also is mounted to the engine with two bolts, I THINK. I'm not positive how many there are, but if you take all three packs off you'll see the bolts.
Old 10-15-2004, 11:42 AM
richtazz's Avatar
I believe the module bracket has 3 bolts on a 90 Lumina, and it's in such a wonderful place (front of the engine block between the engine and radiator) that is so easy to get to.....NOT!!! It is the piece that the coils bolt to, and there are three wiring plugs on it, two on the one end(passenger side of car) and one on the other end (driver's side of car).
