Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 10-13-2004, 04:31 PM
danileblanc danileblanc is offline
Automatic Locks
Hello, 1992 Buick Roadmaster Limited. Does anyone know how to disable the very annoying automatic power locks that occur everytime you shift this car into gear....I know I can disable the power locks by taking out the fuse but I would much rather just disable this feature...and keep my power locks. Thanks
Old 10-18-2004, 05:51 PM
Shub-Niggurath Shub-Niggurath is offline
Re: Automatic Locks
I love that. Shift out of park and they lock, shift back into park and they unlock, hehe. I believe that's sort of a safety feature and there may not be a way to disable it. Good luck, though.
Old 10-19-2004, 08:26 AM
Wink automatic locks
Yeah well I feared that....I had a Mecury Grand Marquis and I was spoiled because there was a way to disable/enable them. Sometimes though there is a way to do something even if it is "skirting" around and by passing something...I just don't know what that something is. Maybe I will just have to tinker on my own.
Old 11-08-2004, 05:37 PM
tinglygravy tinglygravy is offline
Automatic Locks
It is actually quite easy to disconnect the automatic locks...if you look under the dash, you'll see a grey plug coming down from the dash above the gas pedal. This plug should have 4 wires in it. Unplug this connection. It will unplug the automatic locks but NOT the power locks.
Old 11-09-2004, 09:29 AM
Re: Automatic Locks
Thank you very much. I can't wait to try it.
Danielle :o)
Old 11-22-2004, 01:57 PM
Re: Automatic Locks
I looked for the grey plug....I could not find it but I saw a black plug amongst a mess of wires (harness). Could this be the same?
Old 12-22-2004, 02:16 PM
ChrisEJ ChrisEJ is offline
I just looked under the dash of my '93 RM Estate and found a connector on the right side of the neutral safety switch on the steering column. It has a single blue wire. Unplugging this connector disables the automatic door locks apparently without affecting the door locks otherwise. Hope this helps.
