Old 10-13-2004, 04:20 PM
jcteck88 jcteck88 is offline
Unhappy HELP ME PLEASE!!! 1986 Firebird 2.8l V6
I had a huge problemb, a starter bolt got loose and when i went to start it it broke and fried my starter. Well i got it all out and got the new starter in and some one turned my dist. cap and now the car just goes and goes w/o fireing. I am very new to cars and i have no idea what todo so i can get this car started again. It started before and now it is all messed up. If some one could help me please email me lol [email protected]
i think i shouldnt be come an auto mechanic anymore..
Old 10-13-2004, 05:00 PM
Kurtdg19's Avatar
Kurtdg19 Kurtdg19 is offline
Send a message via AIM to Kurtdg19
I know this may sound like a no brainer, but I would make sure you put the plugs back in the right firing order. The 2.8 should have a firing order like this:
If you are looking at your engine from the front. its should be
5 6
3 4
1 2
The #1 spark plug wire should start on your distrubuter cap at the front left, and it goes up in value numerically clockwise. It should look somthing like this:
----3---4---
---2------5---
----1---6---
Old 10-13-2004, 05:57 PM
well thats a start!! i had it all reversed, what do i do to reset the distriburor? some one has turned it on me and i dont know what to do
Old 10-13-2004, 06:17 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: HELP ME PLEASE!!! 1986 Firebird 2.8l V6
Once you have the firing order correct on the cap then have someone stand at the distributer while you are cranking the engine. As you crank it have the person at the distributer turn it slowly in one direction or another it should fire. If you would prefer the mechanics way, slowly rotate the crank with a wrench and watch for it to get to top dead center. To do this remove the valve cover on the side with the number one cylinder and wait until both valves are closed. Replace the valve cover now that the No. 1 cylinder is at top dead center on the compression stroke turn the rotor to the number one position on the cap and reinstall the cap. You may have to remove the distributer to do this but if it is only slightly out simply turn the distributer to align it. It should be close enough to start. You will need a timing light to get it set to factory specs but that should be easy. Tighten the distributer and you are ready to run again.
Old 10-13-2004, 07:28 PM
is their an easier way than removeing the valve cover? a friend told me to put a screw driver in #1 and crank it slowly till the screw driver goes up then take out the distrubitor and then alinge the spinny part over the #1 place to put the spark plug wire on then it should start...
im no wheres a mechanic lol i have the tools and some knowledge but not alot. and i wouldnt trust my friends either
Old 10-13-2004, 10:18 PM
ryanL04 ryanL04 is offline
Send a message via AIM to ryanL04
make sure if you messed with your distributer the timing is correct to. (just a tip) on the distributer makes sure its all clean and no carbon deposits or nothin like that since you already have it off. definately fix the firing order. haha. always good to have that right. ive had a problem with the chip inside the distributer.. well not inside but next to. you MAY have to check that. i have to replace mine once already. ive got the same 2.8 v6.
Old 10-14-2004, 05:35 AM
Pontiac Guy
You can try it using the dowel/screwdriver method but you risk not getting the piston to top dead center on the compression stroke. You can also align the timing marks on the harmonic balancer to make sure you are at tdc on number 1. This is probably a little less time consuming than removing the valve cover.
Old 10-14-2004, 01:59 PM
Re: Re: HELP ME PLEASE!!! 1986 Firebird 2.8l V6
but how can i make the distrubioror right? The timeing is on the car started fine till someptin happend with the starter and thats all fixed but i dont know how to get the distruboror cap in the right position, you may have already answerd this but i am no machanic. I just need to like rotate it some how?
Old 10-14-2004, 02:36 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Hold up, did someone actually take the distributor out of the engine. If so why???
Did you have the spark plug wires off to I noticed in a post above you said you had them backwards but fixed them.
The car should run if the distributor has not been taken out even with the timing off it cannot be far enough off to not start and run. It may run poorly but it should still start.
Also if it just turns over without firing or popping are you SURE that when "someone" messed with your distributor that they did not knock the coil power wire off or unhook it?
Check for spark before you do anything else.
Old 10-14-2004, 03:38 PM
Some one turned the cap like alot and thats it. umm i kinda messed up also. i put a screw driver in the cylinder hole to get when its all set well it did it and broke half of the driver and its loged in the engine. i go to start it and it comes to a dead stop and power shuts off. i cant even move it. i have no idea what to do now........
Old 10-14-2004, 03:48 PM
Blah blah blah
Pull the cylinder head off...
Let me give you some advice. Stop right now and call a mechanic. Please.
Old 10-14-2004, 03:56 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Wow that was the best damn advise I ever seen posted on any site
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-14-2004, 04:07 PM
lol i cant call a mechanic. I dont have the $$$$$$$$$. I have to be my own mechanic lol.... Wheres the cylinder head and what do i do?
Old 10-14-2004, 04:22 PM
FormulaLT1's Avatar
Fight the powwa!!!
Well in the middle of banging your head because you like alot of us don't want to have to whore yourself for the money to fix your ride. Come introduce yourself in the Community forum and maybe we can somehow help you along the way.
Old 10-14-2004, 05:57 PM
Pontiac Guy
It is hard to help when you don't have all the information. If you actually did what you said, you need to call someone that has some mechanical knowledge because you will never get the engine apart let alone tearing it down. I would love to help you but I can't explain how to tear an engine down and reassemble it on this forum. You may even need a new engine if you broke a screwdriver off inside the cylinder as you probably damaged the piston as well as the cylinder head. My advice is the same as Shortbus@af----CALL A MECHANIC!!!!!!!!!!!!!!!!!!
