carputer?
ya well i got bored and decided to build a comp for my car im just tryint to think how im gnna power it , this prolly isnt the corect forums but who cares right? lol
well its a mini itx M10k prolly will use like 70 watts with everything pluged in , im tryin to decide on weather to go with an inverter , or just get a split relay charger to charge a gel battery that would be used for the comp , then just get a dc -dc PSU and put a 12v regulator , the main issuse is when you start the car cause it cranks out like up to what 19v which will start to fry things , and if i went with that how would i power my montior |
Re: carputer?
get an inverter with 2 plugs.
Re: carputer?
1991 Camaro Z28 |
Re: carputer?
eh?
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
Re: carputer?
omg, you're canadian?
Re: carputer?
whos canadian?
Re: carputer?
yeah what of it!
1991 Camaro Z28 |
Re: carputer?
WTF
89 Camaro with lt1/t56/headers,borla exhaust,ac delete, march pulleys, slp CAI,3.73 gears,msd ignition,port & polished heads, reprogrammed pc, free mods, hotchkis suspension,sub-frame conn & weight reduction. |
Re: Re: carputer?
Re: carputer?
I think Geno answered your question. You will require a power inverter. Although I would just buy a laptop if I where you cause they can run off cigarette lighter when the battery is low or just run off its battery. No reason to have one mounted in the car that I can think of.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
Re: carputer?
ya i went with inverter , i just need to pick up a ac/dc adapter and i should be just about done , i just didnt want to spend money on a laptop
Re: carputer?
Grand National. Going fast with class. Voted FASTEST street car on AF. Here is the proof!!! 1987 Buick Grand National. Back in action!!!! 1999 Ford F-250 Tow rig from hell 598 Ft-lbs. ASE Certified in... Mobile AC On Highway medium duty diesel engines. Off highwayy medium duty diesel engines. On highway trucks. Working on the eletronics certification Member ofA.A.N.B.C- Afer against non boosted crews #2 |
Re: Re: Re: carputer?
and right now im considering just doing the other battery cause tryin to find a AC/DC 12v 7A adapter isnt as easy as i thought it would be , the battery puts out 12v 50 cranking amps i believe , i just gota get a gel battery or something i mean it would take days to drain the battery only pulling like 6amps , still not sure yet im still making a case for it at the moment, lol not sure why i decided to take on this project hypsi , when you crank your engine over it bumps the voltage up from what ive read *edit* i remember... war driving |
Re: Re: Re: Re: carputer?
Put a volt meter on your battery and then crank your car. The voltage drops. Current draw increases but your voltage will go from 12v to somewhere around 9-10v. think of as pushing a cart [starter], when the cart is empty, you have you full force [voltage] avaible to the cart. Then all of a sudden 500 lbs is added to the cart, the ammount of force [voltage] that travels through the cart decreases but the ammount of work [amprage] you do increases. Get an amp clamp and volt meter and see for yourself. Don't use a multi meter ammeter, youll blow it. You can use it to check the voltage but not amps. Most only go up to 20 amps. your starter will draw well over that.
