Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 02-17-2002, 05:24 PM
paradyme paradyme is offline
Talking G20 P10 Part Numbers!!!!!!!!!!!
95 P10 owners, Here you go enjoy!
Infiniti part# 13270-53J05 - Valve Cover Gasket -
Infiniti part# 23100-0M810R - Alternator -
Infiniti part# 17251-79912 - Fuel Tank Cap -
Infiniti part# 23300-63J10R - Starter Motor -
Infiniti part# 16400-0M200 - Fuel Filter -
Infiniti part# 46010-62J72 - Brake Master Cylinder -
Infiniti part# 40206-71E06 - Front Brake Disc -
Infiniti part# 43206-42R05 - Rear Brake Disc -
Infiniti part# 41060-6J090 - Front Brake Pad Kit -
Infiniti part# 21503-53J00 - Lower Radiator Hose -
Infiniti part# 44060-6E390 - Rear Brake Pad Kit -
Infiniti part# 21430-4B700 - Radiator Cap -
Infiniti part# 21200-53J00 - Thermostat -
Infiniti part# 21501-53J00 - Upper Radiator Hose -
Infiniti part# 21010-53J01 - Water Pump -
Infiniti part# 46010-1N420 - Brake Master Cylinder -
Infiniti part# 40206-7J101 - Front Brake Disc -
Infiniti part# 41060-0V090 - Front Brake Pad Kit -
Infiniti part# 43206-9E601 - Rear Brake Disc -
Infiniti part# 44060-7E690 - Rear Brake Pad Kit -
The last five part numbers are p11 brakes, stock upgrade for the P10
:flash::jump:
paradyme
95'G20t/AUTO/BLK
STILLEN HEADER/INTAKE/JWT/ECU/S3 CAMS/P11 99 G20 RIMS/
VIPER SECURITY/w/ REMOTE START/ ALPINE AUDIO
Old 02-17-2002, 06:43 PM
Yahnozha Yahnozha is offline
Send a message via Yahoo to Yahnozha
Paradyme: I was just thinking about this, would be a great resource for the FAQ section....here are some for the P11 (mostly cosmetic)
P11 Owners Enjoy
INF-B6150-7J100 Fog Light Kit (Both Fogs, New Relay, New turn light assembly for steering column, Trim Pieces)
INF-26160-4N000 Lamp Assembly Side Flash (Clear Side Markers)
INF-769B0-4J900 Kick Plate Front (Stainless Steel Sill Plate, need 2)
INF-769B2-4J900 Kick Plate Rear (Stainless Steel Sill Plate 1)
INF-769B3-4J900 Kick Plate Rear (Stainless Steel Sill Plate 2)
INF-63840-7J100 Right Wheel Well Plastic Liner (Includes all mounting hardware)
INF-63841-7J100 Left Wheel Well Plastic Liner (Includes all mounting hardware)
P@ - www.customsteel.com
Red 99 G20(t) / UR 2 piece / JWT POP / HS CAI / WW Lip / HS Header / Greddy Evo / S3 cams
Old 02-17-2002, 07:03 PM
Keep It Coming......I have some other part #'s EGR valve, BPT valve, Fuel Pressure regulator, EGR solenoid valve, and Motor Mounts....I'll post them as soon I get a chance....This cuts out allot of guess work.
:jump: :jump:
paradyme
95'G20t/AUTO/BLK
Old 02-17-2002, 08:55 PM
Here's some more part numbers
Infiniti part# 1120-64J06 P10 A/T Motor Mount
Infiniti part# 1121-62J15 P10 A/T Motor Mount
Infiniti part# 11320-64J20 P10 A/T Motor Mount
Infiniti part# 14710-78J01 P10 EGR Valve Assy
Infiniti part# 14741-02E00 P10 BPT Valve
Infiniti part# 22670-78J00 P10 Fuel Pressure Regulator
Infiniti part# 14956-38U10 P10 P10 EGR Solenoid Valve Assy
Infiniti part# 80606-4B704 P10 Frt Door Outr Rh Assy Blk
Infiniti part# 80607-4B704 P10 Handle Assy Fron
Infiniti part# 2240-0M811 P10 Plug Wires
Infiniti part# 22401-1P115 P10 NGK Platinum Spark Plug
Infiniti part# 22162-3S505 P10 Plug Wire Cap
Infiniti part# 22157-46N12 P10 Cap Rotor
Infiniti part# 16400-0M200 P10 Fuel Filter
Infiniti part# 11920-5U011 P10 AC Belt
Infiniti part# 11950-53J20 P10 Pwr Steering Belt
Infiniti part# 999MP-A4025 P10 Weather Strip Cement
Bosch part# 61075 P10 Fuel Pump
Infiniti part# 17342-79900 P10 Packing Fuel Gasket (used w/Fuel Pump)
Bosch part# 13039 P10 Oxygen Sensor
NGK part# NX11-9886 P10 Plug Wires
NTK part# 24075 P10 Oxygen Sensor (Catalytic Converter)
K&N part# HP-1003 P10 Fuel Filter
Infiniti part# 28156-67F10 P10 Rear Speakers
Tip: The door handles are a cheap upgrade for those who have the
early P10 models (91 thru 93) with flat black door handles, Also for me and whoever has the 94 thru 96 models with those ugly little chrome door handles. The Sentra and 200SX both came with door handles indentical to the handles on P10 G20. The part number I have listed here are door handles with the black glossy finished that are listed as NISSAN Sentra or 200SX replacement door handles. These two cars came in many different colors and had the option of same color door handles or flat black handles, depending on the model purchased. I listed these numbers because I know practically everyone has gone through the " I don't give away part numbers Bull***t" Some dealers need to get a grip where all paying customers. It's a shame that I can by parts from NISSAN on line 10 to 20 dollars cheaper than if I walked into my not so local INFINITI dealer and get robbed for a parts purchase. If the dealers could find a way to discount the parts maybe the labor they charge wouldn't be so bad. Everyone chime in, there are more parts to go suspension, interior parts, exterior parts, Let's go keep it coming!
paradyme
95'G20t/AUTO/BLK
Old 02-17-2002, 09:13 PM
frogg's Avatar
frogg frogg is offline
Send a message via AIM to frogg
Nissan part# 84896-2F500 GT Badge (w/ black border)
Infiniti part# 26139-3J100 Corner Light Assembly (Driver's Side)
Troy P.
My "pretty-much-stock" G20
:apoke:
Old 02-18-2002, 05:37 PM
dmh dmh is offline
got this one?
Do you know the right (passenger) side differential oil seal part number for a '95 G20 auto?
Old 02-19-2002, 11:08 PM
Unhappy
NOPE.
:flash:
paradyme
95'G20t/AUTO/BLK
Old 02-20-2002, 03:04 AM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Re: G20 P10 Part Numbers!!!!!!!!!!!
:flash::jump:
Woa...wait how can you use P11 brakes for the P10...i dont think those rotors are compatible. P11 has altima or max rotors on the front now i believe?
-Brian Jones
I got a snake man
Old 02-20-2002, 03:06 AM
Just curious...whats being upgraded? Like whats different
-Brian Jones
I got a snake man
Old 02-21-2002, 12:10 AM
Lightbulb
OKAY. The same way the NX brake upgrade works for the SENTRA and 200SX. The P11 does not have the thickness of a NX rotor but have a larger 11inch rotor on the P11. The P10 has I believe a 10inch rotor. You would have to remove the backing plate on the P10 to make room for the larger rotor. You may have to change the master cylindrer but I'm pretty sure the caliper is the same The wheel measurements are the same. I have the 99 G20 rim on my 95. I first heard about this with the new SENTRA 2000 up have the same 11 rotors found on the 99 and up G20. Now the door handles like I mentioned hear, you can replace either the flat black handles found on the 91 thru 93 G20's or the chrome door handles found on every model made after. My point is and the upgrade is having body colored handles for your G20 like I do. They give your car a more uniform look.:flash:
paradyme
95'G20t/AUTO/BLK
Old 02-21-2002, 12:33 AM
Hmm this is interesting. the P10 is a 10.12 in outer diameter and .87 in thick.
Pads are 4.94in long 1.783in wide and .43in thick.
The backing plate i guess you can just completely remove? Would that be a good thing to do? Whats the thickness on the P11's
-Brian Jones
I got a snake man
Old 02-21-2002, 01:59 AM
This same backing plate is cut if you install NX brakes on SENTRA or 200sx. It's because of the diameter.
:flash:
paradyme
95'G20t/AUTO/BLK
Old 02-21-2002, 02:01 AM
But on them you're also upgrading the calipers...
-Brian Jones
I got a snake man
Old 02-21-2002, 01:39 PM
JsL138 JsL138 is offline
What is the NGK part # for Iridium IXs for a 96 G20 and a 99 G20? I've been seaching this for a while, and still can't find it. I think the 99 uses BKR5EIX-11...
Old 02-21-2002, 03:34 PM
dmh dmh is offline
more g20 part numbers
'95 G20 auto
right differential oil seal
Nissan 38342-8E001 $6.30 list on Feb. of '02
Now if I can figure out which way the seal is inserted...
