Old 10-13-2004, 12:11 PM
gign gign is offline
Power Window Help
Hey im looking for a Wiring Diagram for my driver side Window/Door Lock Switch. I didn't see one in the chilton manual but maybe I just missed it. Thanks for any help, as my window doesn't work and we're trying to figure out what is causing the problem because we're pretty confident its not the motor.
Thanks
Old 10-16-2004, 02:04 PM
Re: Wiring Diagram for Window/Door Lock Switch
i found the wire diagram but heres my problem:
So my driver power window died the other day in my 93 mustang, just stopped going up. The day after the passenger 1 stopped working from the passenger side switch but I could still control it from the driver side. Atm I'm not to worried about the passenger side one because I can still at least control it, but I'd like to fix the passenger one because there is about an inch or more it has to be rolled up to be completely closed and want to fix it before the rain comes. I've taken off my door panel and one wire is not connected, its a red one at the bottom of the switch, but I believe it to be the power window lock because that's never worked.
Originally I thought it was my switch because I didn't notice a decrease in amps in my car when I pressed the switch, but i did some tests with multimeter today and the wire has continuity and i get 12v when i press the switch, so does that mean it's the motor or would i have to check the harness that plugs into the motor to see if that gets 12v before i could make any assumptions.
Old 02-07-2005, 02:20 PM
tyaquint's Avatar
tyaquint tyaquint is offline
Send a message via AIM to tyaquint
hello, do u have the wiring digram for the door? i need it if you could help me out, thanks
