Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-13-2004, 11:14 AM
Dennis Davinroy Dennis Davinroy is offline
motor swap
I'd like to know if a 99 saturn 2.0 dohc sl motor will work in a 96 saturn sc dohc? Will flywheels interchange motor mounts be the same and motor bolt up the same? Will I need to change out the computer etc.? Please if anyone knows if it will be an easy change over or will it be a big pain in the blank? Thanks for your help. Dennis
Old 10-14-2004, 12:11 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: motor swap
umm, yes and no
yes, the 99 and 96 DOHCs are the same, you may need to do some work with the intake and exhaust manifold, if you swap them too depending on if it is a early or later 99. (different styles)
no because there is no 2.0 liter engine for the s-series, unless it was overbored. only 1.9 DOHC, 1.9 SOHC SFI, and 1.9 SOHC TBI
Old 10-14-2004, 10:37 AM
Aleks Aleks is offline
Re: motor swap
Since we're talking about engines, what year cars can I look for to take engine for my '94 SL1 (SOHC)?
Old 10-14-2004, 10:18 PM
Re: motor swap
93 and 94 will swap right in, 95-02 will take a little bit of work.
Old 10-14-2004, 10:26 PM
lntegraLover lntegraLover is offline
Banned
Re: motor swap
how did u guys learn so much about engines
Old 10-14-2004, 11:16 PM
Re: motor swap
lets just say i spend a little to much time on these types of forums. plus i've been in tech school for about 7 months now.
Old 10-15-2004, 11:20 AM
davem3945 davem3945 is offline
99 to 93 motor & tranny swap?
I was given a 93 saturn 1.9 SL2 DOHC Automatic trans. It sounds like the connecting rod is going out. I know of a 99 wrecked car for sale. Will the motor and tranny swap in for the 93? Like the motor mounts and tranny mounts etc, and will I have to transfer the electronics too? any info would be appreciated Dave
Old 10-15-2004, 04:08 PM
Re: motor swap
sierrap615 is great Knows lots and lots.
Thanks, I will look around junkyards for a block to snatch
Old 10-16-2004, 12:22 AM
Re: motor swap
for DOHC only (i hope i get this all right, i doing this from memory)
an EARLY 99 engine(alumium intake manfold) will fit in most 93s and all 94-98s.
a late 99 engine (plastic intake manifold) will fit 00-02
91, 92, and a very small handful of 93s are interchangable with each other, but nothing else(unless you replace the crank or the entire wiring harness and PCM). however, the 91s had different engine mounts, some conversion work is nessacary
that is just a basic guideline. of course, all years had little tweaks and a few small adjustments may be nessacary. for the 93 -> 99, the engine and tranny will swap in if it is a alumium intake 99. and you will need the 99 wiring and PCM(as well as add a rear O2 unless you swap the cat too)
Old 10-18-2004, 10:46 AM
93 -99 engine swap
Thanks for the info on the engine swap very informative. The guy sold the car over the weekend "bummer" so looking again for a motor. thanks for your help.
Old 10-24-2004, 08:59 PM
brokenheadz2003 brokenheadz2003 is offline
Send a message via ICQ to brokenheadz2003 Send a message via AIM to brokenheadz2003 Send a message via MSN to brokenheadz2003 Send a message via Yahoo to brokenheadz2003
Re: motor swap
if u got a first gen anything it has the same motor 1.9 DOHC/SOHC. if you got the SOHC you can switch heads in an afternoon. but taking a1.9 and putting the 3.0 v6 in its place is a hell of a challenge. if you got the time and the money it is possible
