Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-13-2004, 09:51 AM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
code p0141
finally i went to autozone to check the CEL of my ESI, they told me that the problem was the oxigen sensor (P0141) but the guy said something about first socket or something like that, someone know which one is the o2 sensor "1 socket", and how much it will cost to me? cause i almost know nothing about the n/a engine so please help me. thanks.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 10-13-2004, 01:42 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: code p0141
Are you sure he didn't say "bank 1"? If he did indeed say "1 socket" I don't have any clue what he ment.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-13-2004, 01:43 PM
Re: code p0141
yeah bank 1 thats what they had said, sorry
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 10-13-2004, 02:32 PM
Re: code p0141
No biggie, bank 1 just lets you know where the o2 sensor is located. Typically 4 bangers only have one bank, V motors have 2. Anyway, sounds like you need a new o2 sensor. Do you have access to a logger to see if the voltage is cycling? As far as cost, I think they are around $100. Just make sure you get an OEM sensor. Good luck.
1997 Spyder GS-T
5-Speed
Old 10-13-2004, 05:35 PM
Re: code p0141
oh shit $100, i don't have a logger and i think is going to stay like that until i finish with the other car .
Thanks a lot man.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 10-13-2004, 07:27 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: code p0141
Looks to me like that cose is for bank 1 (we only have one as explained above) sensor 2. That would be the post cat sensor. Do you still have a cat?
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-13-2004, 10:15 PM
Re: code p0141
yes i do still have the cat on my esi, the car is competly stock it doesn't even have rims
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 10-14-2004, 09:21 AM
AF - Advisor
Re: code p0141
The rear o2 sensor may have died then.
Kevin Jewer
Old 10-14-2004, 10:57 AM
Re: code p0141
the o2 sensor of the gs-t is the same as the one of the esi? cause i have an extra one.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 10-14-2004, 09:57 PM
AF - Advisor
Re: code p0141
I dont think they are the same.
Kevin Jewer
Old 10-14-2004, 10:22 PM
Re: code p0141
shit if they are not the same it is going to stay like this for a couple of more month until i finish with the gs-t
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 10-17-2004, 12:41 PM
Flipz Flipz is offline
Hi,
I got a similar problem on my 96 GS Spyder. I got a Check Engine sign a few days ago and checked with a machine what code it will return. It returned P0420 - Catalyst Efficiency Below threadhold. As far as I hear it is connected with problems of the o2 sensors and cat converter. I was wondering whether this message could show which one of these I need to change or I should open the car before knowing. The service I went to asks for 600 for cat converter change and I could find o2 sensors from bosh for 80 bucks each so o2 sensors should be easy to change but cat converter is a bit over my budget. Do you think changing just the front and rear sensors will fix the problem (or do you know where I could find a cat converter for less than 600?)
Old 10-17-2004, 09:42 PM
AF - Advisor
Re: code p0141
That code (catalyst system efficiency below threshhold (bank 1)) is almost alwyas the cat, or lack of one. EIther way, you cxan get a cat from suumit for ~100 bucks and have flanges welded on to it. Though they may be too big for your exhaust, you'll have to look into it. Also, how many miles oare on the car? I belive the dealer has to cover emissions components for a LONG time, at least 100k miles.
Kevin Jewer
Old 10-17-2004, 10:49 PM
Hi,
So does this mean that the o2 sensors might be ok? My car is on 80K miles. Not much for a 96 but still it hasn't been taken care much for so I guess this might be the problem. What is suumit btw? is it a store? I tried eBay and the cat converters there are 30 bucks but they are all for test and off-road performance only.
Old 10-18-2004, 12:14 AM
AF - Advisor
Re: code p0141
www.summitracing.com
Kevin Jewer
