Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-13-2004, 09:16 AM
spasticone spasticone is offline
Unhappy 91 Laser not won't run.
I have a 1991 laser 2.0 auto.
I had the trans pulled and fixed by a local shop. When leaving after its 3rd visit to the shop, I smelled a hot electrical oder and the car shut down.
After towing home and doing some diagnostics, the car runs when fuel is squirted in the intake, but not on its own. Also it has fuel pressure at the injector rail. Spark is great and not the problem.
Can anyone help me out??? I know there are some Mitsubishi guru's on this forum, so let me know what you think.
Old 10-14-2004, 12:13 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: 91 Laser not won't run.
pop off the electrical connector on one of your fuel injectors and see if you have power there while you crank the engine. if you do then the problem is probably clogged injectors since you have fuel pressure. if you dont have any power at the injectors then start looking for loose connectors or burnt wires.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
