Old 10-13-2004, 09:56 AM
tbacon1 tbacon1 is offline
Plastic shield on lower front bumper ...
1999 Silverado, Auto Trans, 5.3L eng, 4WD
I want to remove the plastic shield that is clipped to the bottom of the front bumper but i'm having trouble removing the plastic split pins that hold it on. they look like they are made to remove easily, but i'm quite the novice mechanic. should i even bother removing them carefully and reuse them or should i just rip them out and buy new ones?
Thanks ...
Old 10-13-2004, 10:08 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Plastic shield on lower front bumper ...
Next time it rains, go get stuck in a deep ditch!! That'll rip it right off! lol, just kidding, you should try pulling it forward, away fromt he bumper, I think thats how it comes off.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-13-2004, 11:26 AM
jumpingjack66's Avatar
jumpingjack66 jumpingjack66 is offline
Send a message via Yahoo to jumpingjack66
read your ownersmanual
2000 Silverado Victory Red, standard cab, short bed, short wheelbase, 4X4, 4.8L, 5 speed, 4:10 locking rear diff, K&n FIPK, Ryno lined all the way over bed rail, heavy half suspension,factory skid plates,Fog lights, BFG 285/75/16 A/T's, dashmat, Stealth Radar.
lots of special options some installed by me!
1980 Suzuki GS1100E Super fast
Old 10-13-2004, 12:09 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
I found the easiest way is to pry each spot with a flathead screw driver. Just curious though, why do you want to remove it?
*Under Construction - New sig to debut*
Old 10-14-2004, 06:09 PM
A portion of the shield has been pulled out of place and is not being held on by those clips but the clips are still in place. It appears there is a way to remove them without destroying them so i can re-attach the shield like it supposed to be. i'm just gonna rip them out and go by some new clips. they can't be that expensive ... ha, gee, i've never said that before!
I also lost my owner's manual, so i can't see what that has to say about it.
Old 10-14-2004, 08:58 PM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
OK here's how it works. The pins are actually each made of two pieces: a plastic ring sort of thing that is put in place, and then a plastic peg sort of thing that is stuck through it. If you examine them closely from the correct side (its cold and dark outside I aint goin' out there to look!), you will see a circlular piece of plastic with another circular piece of plastic inside of it, and you simply jam a flathead screw driver underneath the inner circle, and pry it right off. I had to figure that out myself when I installed my grille gaurd, as the grille had to be pulled to access the bumper bolts. That's how it is done.
HOWEVER!!! In the owners manual, it says that the air dam (the piece of plastic you are talking about) should not be removed for long periods of time, as it can cause improper airflow to the engine.
All of this is detailed, with pictures, in the manual of my '04 in the off-road driving section, page number 4-20. Oughta be in yours regardless of year. Let us know if you have any problems with air flow.
Old 10-14-2004, 10:44 PM
sc_customs's Avatar
sc_customs sc_customs is offline
Send a message via AIM to sc_customs Send a message via MSN to sc_customs
Re: Re: Plastic shield on lower front bumper ...
Originally Posted by tbacon1
Ai'm just gonna rip them out and go by some new clips. they can't be that expensive ... ha, gee, i've never said that before!
I think they're like $7 for a set of four, and I know it takes more than four to secure the air dam properly.
Not surprising these plastic pieces are so expensive. We are talking about GM here...quality parts (i'm not being sarcastic...ok maybe a little)
______________________________
2000 Silverado 4.8L V8 (Converted from 4.3L V6)
Edelbrock Ceramic Coated Headers
K&N Fipk Gen. II
Superchips MAX Tuner
Flowmaster 40 Series DF w/3" pipe
Poweraid TB Spacer
Flex-a-lite Electric Fans
3.73 gears w/Eaton posi
Whipple on hold
And those are just the performance mods...
Old 10-16-2004, 08:18 PM
I just read the owners manual. Since they do not go into any inclusive detail, I believe they included that in there so they are not held responsible if something goes wrong while "Off-Roading" as they say. Basically a clause to keep them from getting sued in any way, shape, or form.
On my third airdam by the way. Damn parking blocks.
