Hey all
Came across a strange problem thought I would post it here to see if there is anything I missed. About 3 weeks ago I replaced the front pads on my blazer. Started to squeek about 2 days before that, Just started hitting the wear indicator on the passenger wheel, Drivers was not far off. When I removed the pads I inspected them and found wear to be normal. No Pie shaped wear everything even and square. There were no markes in the rotors at all and still well within spec. I didn;t cut the rotors at that time. I also replaced the slider kits at the same time just as a preventitive maintaince item at the time. For the sake of $10 figured I may as well. The first day I took it for a test drive and all seemed well, Nice firm brake and seemed like I was ok. The following day I was doing some running around town and after getting the brakes really hot noticed some serious brake fade. It was bad enough thought I had popped a line or something. Anyway rechecked what I had done and noticed that I had left the top off the master cylinder. Not completly off just a little loose from when I was resetting the Front Calipers. I didn't loose any fluid and there was still lots in the resivoir. I snapped the top back on and the brake went back to normal. HOWEVER now yesterday the problem came back. If I get the brakes really hot I will experience brake fade and the Drivers side front brake bads will start to smell like they are clamped on tight but they are not. I have checked the sliders and they look OK to me. I am not getting any SES or ABS lights on the dash. Just the smell from the brakes. Anyone have any ideas when might be going on here?
I love these trucks !! I have had an 84 and 89 Pickup X-cab P/U also assorted 2 Dr Blazers. I now own a 97 4 Dr. I love these trucks !! Still a work in progress but ... http://www.cardomain.com/memberpage/761008 ![]() Macgyver Ontario, Canada |
Re: 97 Blazer - Brake Fade
What type of pads did you use?
Because to me it souds like cheap cardboard type pads that are overheating. Fireplug |
Hi Thanks for the reply;
I bought the best pads the parts store had. They cost almost double of what the "economy" bads would have. I cannot remember the name on the box but it was a black box with Big yellow letters. First time for me but it had a lifetime "certificate" included with them and a form to fill out. I used to work in a parts store and am familiar with differnt quality of parts. I bought the best that was available. J
Does you truck of 4 wheel disk brakes?
No, it has front disk and rear Drum
J
Make sure you adjust the rear brakes , they might be way out of adjustment causing the front brakes to work harder.
The rear self adjusters are worthless Fireplug |
umm, interesting thought, I will give it a try tongiht and let you know
J
Top up the master cylinder.
Re: Re: 97 Blazer - Brake Fade
Did you lose any fluid when you compressed the pistons to get the front pads on? You may have got some air in the lines. (I just had this happen last weekend, only needed to bleed the rear brakes to get a steady pedal, start from the passenger rear, to driver rear, then passenger front, to driver front) |
