Old 10-13-2004, 05:40 AM
Bravetex Bravetex is offline
Engine Temperature Fluctuating
Engine temp bounces from normal up to just below redline. Hangs just below redline on gauge, then drops to normal. Seems to happen more often at idle when sitting at red lights, but not always.
Changed the thermostat twice (195 degrees F).
Old 10-13-2004, 12:13 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Engine Temperature Fluctuating
if it's bouncing around like crazy then your coolant temp sensor is either bad, or a wire is grounding out. that's my best guess.
Old 10-13-2004, 12:17 PM
Sorry, I should have been more specific...the bounce I described is not a rapid bounce like a loose connection would give. It's not a predictable cycling back and forth, often times it's running at normal temp for long periods of time, on trips across the city. Then it goes up to just below the redline, holds, then drops especially when the engine rpms increase.
Old 10-13-2004, 12:54 PM
Genopsyde's Avatar
The President
it goes up to redline durning acceleration, or while coasting? check and make sure nothing is blocking the radiator, and check if fluids are mixing, ie: coolant/oil.
Old 10-13-2004, 01:48 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
its not out of the ordinary for the temp to rise while sitting still in traffic, however it should not jump that much. it almost sounds like a coolant flow problem, if the temp goes down when increase the engine RPM. do you hear the cooling fans turning on?
*Better power-to-weight ratio than a C6 corvette*
Old 10-13-2004, 10:51 PM
justlearning justlearning is offline
Send a message via AIM to justlearning
yeah i too had problems with my engine stayin cool and replaced the thermostat but i still had the problem i took out my radiator and reverse flused it and put a good quality thremostat in and problem sovled so i assumed i had a clogged radiator or my thermostat was gettin stuck open or closed but i still cant get my fan to come on even after changin the temp sensor and the relay this to could be your problem, if your fan isnt kicking on i have to keep my air on low to get the fan goin
Old 10-14-2004, 04:53 AM
Re: Re: Engine Temperature Fluctuating
The cooling fan does come on, however, I'm not sure if it comes on at the proper time. I'll observe and let you know.
Old 10-14-2004, 11:10 PM
if u have a third gen then i think it isnt supposed to kick on till like 220 which is ridiculous and why most people change it
Old 10-14-2004, 11:19 PM
yeah, the fans are programmed to turn on at 220, but that is well below the red on the gauge...
