| Off-Topic Talk about anything other than cars. |
will a 245/45/17 fit a 2g rear or front and rear?
I got some free tires (Conti GT's) to put on my 03 GTS rims. They are 245's though.
Also the other tires are 225/55's they are taller than the 245/45's and the stock tires. What could happen if I temporarily used them on the front?
1995 Talon Tsi 5spd. White, 03 GTS wheels, Injen Intake, HKS super seq BOV, Greddy upper IC pipe, el-glo gauges, HKS turbo timer, Autometer Boost and AF gauges. 2003 Nissan 350z 6MT, Redline, 19's, 100 shot NOS fogger, many more mods... 1997 Honda del Sol FOR SALE!! |
Re: will a 245/45/17 fit a 2g rear or front and rear?
first of all, continentals are sh!tty tires. second of all, the tires will fit the rims, but will stick way out past the rim edge (i'm talking as much as an inch or 2 on each side).this will probably cause rubbing.
http://machv.com/howlarofwhee.html that should answer you question
![]() If it has tits or tires it will give you problems, but atleast you can fix the problems with the tires 2007 Trailblazer - stock 97 GS-T -> lots of mods 98 GS ->total loss, now being parted out |
you wont pass inspection with different size tires on the front then on the back
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
OK so it is my understanding that an AWD should not run different rolling diameters front to rear because it could damage the drivetrain.
