Old 10-12-2004, 09:30 PM
JLSACESUP JLSACESUP is offline
1995 Taurus Wagon 3.8L Motor Mount Replacement
Does anyone have any shortcuts for replacing the right front motor mount. My chilton manual says to unbolt the ac compressor to gain access to the top nut. In order to remove the ac compressor it looks like I need to remove the coolant/washer bottles, and also remove the power steering pump. If somebody has a shortcut, please help me out. Thanks
Old 10-13-2004, 12:45 PM
billy bronco billy bronco is offline
Re: 1995 Taurus Wagon 3.8L Motor Mount Replacement
No short cuts, start unbolting, its about a 6-8 hour job, good luck, I've done two!
Old 10-14-2004, 02:31 AM
Well thanks for the info. Just finished the job. Not much fun but it only took me 4 hours. Shocked the heck out of me. A few tips = It is easier to get to the upper nut if you first remove the power steering pump and the ac comp.
Old 12-10-2004, 02:57 PM
Angel Martinez Angel Martinez is offline
Hi there JL,
You may have already fixed your problem by now, but to benefit the next guy: I discovered that the only thing standing between that top nut of the motor mount and you is the hose that goes to the back of the AC compressor. If you recover the AC refrigerant, you can disconnect that hose and you're home free. It'll take I hr. after the refrigerant is recovered.
