Old 10-12-2004, 08:39 PM
jackmalone2001 jackmalone2001 is offline
third brake light does not work
anyone know if there is a relay or module in between the fuse box and the third (center high mounted stop light) brake light? My two lower brake lights work, but the one in the rear spoiler does not. I took a volt meter to the bulb sockets wires and did not get a reading. The fuse is good but no light...
(1994 V-6 Camaro)
before:
after:
Old 10-14-2004, 11:01 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: third brake light does not work
cant remember, but on third gens there is a contact pad next to the hatch pulldown, that sends the power to the third brake light, so if its corroded, or if the circuit is open somewhere behind the interior trim, it would cause your problem.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 10-14-2004, 11:16 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
im pretty sure that the fourth gens third brake light is powered from a line run through the roof and into the hatch directly back of the rear dome. im not sure on that, but you might want to look there...
*Better power-to-weight ratio than a C6 corvette*
Old 10-16-2004, 10:27 AM
NINÅ's Avatar
NINÅ NINÅ is offline
Third Dork Lite Not Needed
(1994 V-6 Camaro)
Don't fix it. All brake lites is just another way of dumbing down drivers. I removed mine and replaced the back glass with a new one for that 'clean look'.
REFUSE TO LOSE
Old 10-16-2004, 12:53 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: Third Dork Lite Not Needed
REFUSE TO LOSE
Don't fix it? do you WANT him to get rear ended? jackass
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 10-16-2004, 03:42 PM
89IROC&RS's Avatar
yeah, simple rule of law, if you have a third brake light it has to be operational, its called factory safty equipment, and you gotta have it. otherwise your car will not pass inspection, and you can get tickets for it. gotta say nina, usually im pretty impressed with your advice, but that was pretty dumb.
