fuel pump-maybe
OK. I have seen notices on the board about fuel pumps on 97 suburbans.
I have been having the following symptoms: 1. Push gas pedal hard no improvment in speed or RPM's. 2. Start the engine and it will stall shortly after starting. 3. I replaced fuel filter thinking that was cuprit. a. I have done this every 30k up to now. What do you all think it could be. There are 95K on the vehicle. Maintained to the book and use only synthetic in it, oil and all lubes. Thanks in advance. e |
I checked the fuel pump for initialization. It initializes. I guess I will check the relay. Seems that would not allow the pump to initialize then.
Re: fuel pump-maybe
Also when you first initialize the pump and try it again, you have to wait about 10 seconds or so before it will do it again. By the way i'm not a professional mechanic, but I have worked on cars for over 30 years and I am a mechanical engineer that works with MRI and CT scanners. So to me machines are machines and they can all be fixed.
