Old 10-12-2004, 03:52 PM
MustangGT_00 MustangGT_00 is offline
Throttle Body Question
I have a 2000 GT with a 5 speed. The only mod I have done so far is a K&N intake. I am getting ready to buy a cat-back exhaust and possibly a larger throttle body as well. Would it be a worthwhile investment to go with a 75mm throttle body to complement the intake/exhaust or should I just stick with the stock one? Would I need to replace the MAF also to make it run right?? Thanks.
Old 10-12-2004, 06:11 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Stick with the stock 65mm. The 75mm one is for highly modified engines. You'll lose a lot of torque with the 75mm. Try going for headers and gears if it's in your budget, to accompany the intake/exhaust. You don't need to replace your MAF sensor, it will adjust to your mods fine.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
Old 10-12-2004, 08:21 PM
wildstringer's Avatar
wildstringer wildstringer is offline
i ve heard that alot too .A couple friends of mine put on a 70 or 75 mm t body and went back down to a 65mm
"If the devil danced in empty pockets, He'd have a ball in mine "
87 LX 5.0 - I'm not even going to say what I've done to the car cause when I see how much more I want to do I wanna cry.
Old 10-12-2004, 09:54 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Instead of a bigger TB I would look at getting an aftermarket plenum. There getting good gains with the stock TB and MAF but aftermarket plenum.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 10-12-2004, 10:01 PM
brentmcq brentmcq is offline
I've heard that too about going too big on the throttle body but I did it anyway and don't regret it. Basically what I noticed is an expanded torque curve particulary in the mid to upper range. I didn't notice any sacrafice on the low end but I'm also running 390 gears thus I'm into the rpms pretty quick. My motor is stock except the usual bolt ons and tuning. I also honed out the stock plenum with a dremel to get rid of all the stock castings and port matched it to the Tbody. I had to remove 1/8 to 3/16 of an inch of aluminum off the stock plenum to match to the tbody. If I didn't do this I think the performance would definately have dropped simply due to bad airflow. You'll have to do this or buy a C&L Plenum to match the bigger Tbody. Hope that helps. Good luck.
2000 GT 4.6L 5spd, BBK cold air, BBK 75mm TB, Bassani catted X-pipe, (no headers) FM catback, 390 gears, SCT chip, Steeda Pulleys, ported stock plenum, Comp Cam XE262AH. RWHP 260, Torque 282
