Old 10-12-2004, 03:26 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Question Fuel injectors.
The current fuel injectors I have are 19lb. I was thinking of 24lb as the next perfomance upgrade with the mass air meter. My question is will I need a bigger fuel pump, and will their be any hp gain with the 24lb oppose to 19lb? Are 24lb for highly modded engines?
Thx.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
Old 10-12-2004, 05:06 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: Fuel injectors.
You won't need 24lb until swapping heads/cam/intake. Even then it's overkill some of the time.
I'm assuming you're talking about the '88 in your sig. I'd do a 255 anyway for future use. Cheaper than a Ford pump too...
If you ever do a dyno tune, install an adjustable fuel pressure regulator and at least a 190 LPH fuel pump before doing so. That way you can crank your pressure a bit if needs be...
Aeromotive/Paxton/BBK FPR's are all made the same, hit and miss on if it's good or bad. My Aeromotive has been good for the last 20000 miles, but some have had bad experiences.
Kirban is always a good bet.
As for pumps, no matter what brand you get it is made by Walbro so get the best deal.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
