Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 10-12-2004, 12:03 PM
mikeroo mikeroo is offline
help... Idle issue
I have a 98 ranger with some idle problems.. It does either 2 things. It will idle high when I put the clutch in (2K) or it will almost stall when I push the clutch in.
If my idle is high when I push the clutch in I can come to a stop and tap the gas. This drops it back down to normal range.
Any suggestions???
Old 10-12-2004, 10:07 PM
RXtony7 RXtony7 is offline
Send a message via AIM to RXtony7 Send a message via Yahoo to RXtony7
Re: help...
Not a clue I have a 98 too and mine has never done that. My high idle works as it's supposed to, so yours is probably a computer problem.
Street racing is bad...mmkay
1986 Mazda RX-7 GXL
No rotor no motor
1998 Ford Ranger
4 bangin' at it's best
www.firstflightcruisers.com
Old 10-14-2004, 10:37 PM
freeclimber freeclimber is offline
Re: help...
Your truck controls idle with the idle air control valve. Sounds like it's sticking. Check your throttle plate for binding too.
