Old 10-12-2004, 11:36 AM
sirinteg sirinteg is offline
Car sputters when I give gas. Help!!!
I am running a B16A1 and I had a bad distributor. My car had been sputtering when I drove it, and I figured it would be the distributor. It still sputters when I give it gas. The idle goes up and then begins to drop as I hold the gas pedal in place. It almost seems like it is not receiving any gas. I have replaced the distributor, fule filter, used injector cleaner. and I still don't know what is doing it. Does anyone have any info. that can help?
Old 10-12-2004, 01:24 PM
CRXsiZCpa's Avatar
CRXsiZCpa CRXsiZCpa is offline
Re: Car sputters when I give gas. Help!!!
Is the ECU throwing any codes?
Old 10-12-2004, 03:43 PM
Hybrid1990crx's Avatar
fule pump?
Old 10-13-2004, 07:12 AM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
you said you changed your distributor, but did you change your plugs and wires as well? My car had the exact same problem... I had a fouled plug in there... horribly corroded. Check those plugs. Also check your timing.
Old 10-16-2004, 11:32 PM
I checked the spark plugs and I have oil in the spark chamber. I will replace the sparkplug chamber seals, but I doubt that will be it. I don't think it is a spark problem. It really feels like it is a fuel problem. A while back I had to change the main fuel realy. It was doing sort of the same thing and that was fixed. Also, about a 1 1/2 years ago the valve in back of the throttle body (IACV Iforget what it is called) gave some problems. I never replaced it because they told me to just clean it with throtle body cleaner and put it back on. that seemed to work also. Now I am wondering if that is what is acting up again. Does anyone have
