Old 10-12-2004, 11:29 AM
crazy_quick crazy_quick is offline
what is good on a first gen engine (91-92)?
Just wondering if there is anything better on the first gen engines then on the second gen.
Old 10-12-2004, 11:38 AM
Igovert500's Avatar
blue + red light magnet
Re: what is good on a first gen engine (91-92)?
The gearing is better for the 1/4 mile on the first gen 5spd vr4s, than the 6spd vr4s....Also the first gen ECUs are ALOT easier to datalog and monitor for knock...but that is more the transmission and ECU rather than the engine. As far as the engine...I can't really think of anything that would be more desirable from the first gen over the 2nd. However, there isn't anything wrong with the first gen engines, simply Mitsu improved them over time to handle power better. Many of those changes don't really matter unless you are planning on more than 500hp...but nonetheless, they are improvements.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-12-2004, 11:43 AM
whats the deal with the '99 lifters, are they better?
Old 10-12-2004, 12:28 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
1st gen engines have a 2-bolt main, whereas 2nd gen engines have a 4-bolt main.
Yes, the 99 or 3rd gen lifters are better than the 1st, 2nd gen lifters. The design for the 1st/2nd gen lifters is simply poor as it does not allow sufficient oil lubrication around the top of the lifter (see www.3sxperformance.com , section engine uppper for more). 1st/2nd gen lifters are not, however, bad in any way. They still function properly. Sometimes you will here a ticking sound from the engine...this is the infamous 'lifter tick' that plagues all 3000GT/Stealths...some have it, some don't, some will get it. Lifter tick will not harm your engine, its just an annoying sound. The only reason to upgrade to 99/3rd gen lifters is to get rid of the ticking noise, but before taking such an exepensive route, try chaning your oil, maybe oil additives, and different oil filters. 3sxperformance sells 3rd gen lifter for 400, but dynamic racing sells em for 300.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-12-2004, 12:55 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
So what exactally does that mean, I've heard about it but not precisely what it is and what practical difference it makes.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 10-12-2004, 01:07 PM
Igovert500's Avatar
2 vs 4 bolt:
Read:
http://www.stealth316.com/2-2bolto4bolt.htm
http://johnmonnin.netfirms.com/4bolt.html
And here are pictures of the difference:
http://johnmonnin.netfirms.com/4boltPictures.html
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-12-2004, 01:14 PM
Thourun's Avatar
Thanks! Pics and reading material what more could I ask for.
1995 3000GT VR-4
Old 10-12-2004, 01:21 PM
Igovert500's Avatar
Re: Re: what is good on a first gen engine (91-92)?
Half naked girls....free beer....and a vr4...although I don't know how well I could provide you with all of those...
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-12-2004, 01:39 PM
Thourun's Avatar
Yea I guess theres alot more I could ask for but like you said I ain't gonna get it from you lol. So the 93 had the 4 bolt and tougher crank?
1995 3000GT VR-4
Old 10-12-2004, 01:57 PM
Hotshot8792 Hotshot8792 is offline
91s and the first half of 92s have a cast crankshaft and cast rods and a 2 bolt, and an 18-spline transmission
the second half of the 92s and newer have forged crankshaft and forged rods and a 4 bolt, and a stonger 25-spline transmission
all cars came with cast pistons
1st gen's have 5-speeds
2nd gen's have 6-speeds
the difference in horsepower is a restrictive nipple that came in the 1st gen boost solenoid, which can be easily removed to match 2nd gen horsepower
although its just better to buy an $18 mbc and a aftermarket boost gauge
as far as N/A's, all n/a's have 2-bolt blocks, but the cast to forged internals changed with the vr-4s
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 10-12-2004, 05:22 PM
Thourun's Avatar
Thanks that was very helpfull! So how does one tell wheather they're looking at a 92 from the second "batch"?
1995 3000GT VR-4
Old 10-12-2004, 09:23 PM
Linebckr49's Avatar
i'm a bit confused. i thought all cars from 92.5 on had the 4-bolt mains, according to your post. but did this only apply to VR4s from 92.5 on? Also, when looking at John Monin's explanation http://johnmonnin.netfirms.com/4bolt.html , he says that in order to determine whether you have a 2-bolt or 4-bolt, simply look at the type of CAS (crank angle sensor) you have. On my 93 3000GT base, i have the latter type of electrical CAS, mounted next to the timing belt cover.
So are all NAs 2-bolts, or do i have a 4-bolt?
thanks
93 3000GT base
Old 10-13-2004, 08:53 AM
So what is so good about a 4 bolt compaired to a 2 bolt?
Old 10-13-2004, 02:26 PM
Igovert500's Avatar
Did you read the links I gave...
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
