Old 10-12-2004, 10:13 AM
YsOne YsOne is offline
tail gate won't open
I have a 2000 Silverado and the tail gate won't open. It appears that possibly one of the rods between the handle and the latch is broken. Any suggestions on how to get it open?
Old 10-12-2004, 10:28 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Re: tail gate won't open
Usually there is a blue or green clip that is notorious for breaking. The clip is the one the holds the latch rod to the gate handle. Dealers have the parts in stock, you will need to un-bolt the handle from the backside of the gate to get to the clips.
Old 10-12-2004, 10:29 AM
Nigel215's Avatar
Nigel215 Nigel215 is offline
sounds about right
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 10-12-2004, 10:59 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
All I did is remove the big outer trim piece from mine, and replaced the little plastic thing w/a part from Advance auto parts for $.95 . But be careful when doing this, the trim breaks easily, as I found out the hard way.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-12-2004, 01:09 PM
MAMorse MAMorse is offline
tailgate
Had the same problem. Used 2 nylon cable ties to firmly reattach rod to broken plastic part in handle. Has held up for a year.
Old 10-12-2004, 07:22 PM
gremlin96 gremlin96 is offline
remove the handle and pull on the rods it will open. most auto part stores have the part to atach the rod back to the handle.
Old 10-12-2004, 09:01 PM
skipr skipr is offline
While we are on this subject, I am having a hell of a time trying to get the driver's exterior door handle back in with both rods (latch release and door lock ) installed at same time. I had to sacrifice the door lock to get handle mechanism back in door. I've tried to reach from inside with panel cover offf but can't reach, there's a post in the way.
