Old 10-12-2004, 02:23 AM
dexorated dexorated is offline
Send a message via AIM to dexorated
1990 Talon Parking Brake Stuck on?
In my Talon, when I take the parking brake off, the light stays on. The car seems slow to accelerate, and it squeaks when driving in reverse. I'm guessing the parking brake is stuck on somehow? Any advice?
Old 10-12-2004, 10:00 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: 1990 Talon Parking Brake Stuck on?
pull your back wheels and spray the parking brake cables and springs with wd40. you could try spraying it with the wheels on but if you can jack it up and pull the wheels its easier.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 10-13-2004, 04:28 AM
Where is the parking brake cable located? Thanks
Old 10-13-2004, 05:19 PM
take off your back wheels and you'll see a cable going to a sping loaded lever on the back side of the caliper/rotor/brake assembly spray it all down with wd40
-1stGenRocks-
