Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-12-2004, 01:12 AM
mongooze mongooze is offline
rb25det in a 300zx
can i use the na tranny of a 90 if i drop a rb25 in it.what all would i ned to do. motor mounts? etc.? what about the exhaust, how do i go about getting an exhaust do i just use the 300 exhaust or the skyline??
Old 10-12-2004, 01:17 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
um..you would have to get a custom mandrel bent exhaust built unless you could possibly weave the skyline exhaust through the chasis of the 300zx.
you would need motor mounts, custom brackets for your radiator rb25det radiator, rb25det tranny, ECU, custom driveshaft. change the fuel pump over, and then all the necessary piping and wiring. thats all i can think of off the top of my head. probably missed a few things.
ZedEx Crew Member #4
Old 10-12-2004, 03:09 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
Re: rb25det in a 300zx
I believe that the TT tranny (VG30DETT) bolts right unto the RB series engines...
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
Old 10-12-2004, 04:00 PM
Hodo Hodo is offline
Still BIG money to do that swap. Almost as much as the VQ35DE Idea I had.
Old 10-12-2004, 04:10 PM
musicsurfman musicsurfman is offline
Send a message via AIM to musicsurfman Send a message via MSN to musicsurfman
One: The 300zx Radiator Is More Than Efficient Enough For The Rb25det.
Two: The Stock Trans Will Work If You Use The Rb25det Front Case/bellhousing.
Three: Exhaust Will Be All Custom
Four: Motor Mounts Will Need To Be Fabbed, Along With Trans Mount And Driveshaft If You Swap The Tranny.
Five: The Fuel Pump Should Be Sufficent But Will Need To Be Changed If You Plan On Upgrades.
SIX: DEPENDING ON YOUR MOUNTS YOU MAY NEED TO CHANGE TO A REAR SUMP OIL PAN AND PICKUP.
This Is All Assuming You Are Doing This To A Z32. If You Are Doing This To A Z31 It Will Be Alot Easier Because The Z31 Came With A Rb20det In Japan.
IF I AM TYPING IN CAPS (LIKE NOW) I AM SORRY BECAUSE I AM AT WORK (DATA ENTRY) AND I HAVE NO CAPS LOCK BUTTON AND NO WAY TO CHANGE MY UPPER CASE LETTERING. SORRY!
EMAIL CONTACT:
[email protected]
Old 10-13-2004, 04:38 AM
Zgringo Zgringo is offline
Iv's right, if you use the RB bell housing.
Old 10-13-2004, 11:40 PM
i found the rb25det engine with tranny( can i use this trany for the 300) ecu and wiring shit anything else i need besides the exhaust,radiator and custom mounts
Old 10-14-2004, 12:07 AM
dont know other than a soddering gun.
Old 10-14-2004, 01:37 AM
Z Cars Fanatic
and alot of patience and beer!!!
Old 10-14-2004, 09:46 AM
You Can Use The Rb25det Tranny But The Shifter Position Is Going To Be Hard To Get To Fit.... The Z32 (and Oddly Z33) Uses A Extended Linkage For The Shifter While Most Other Trannies Are Direct.
Ecu You Must Use The Rbs And The Wiring You While Have To Sit Down With Both Wiring Diagrams And Splice Them Together.
You Don't Need A Radiator.... If A Stock 240sx Radiator Can Cool A Rb25det Than A 300zx One Can!
EMAIL CONTACT:
[email protected]
Old 10-16-2004, 01:19 AM
yes! beer!....how about an rb26dett
Old 10-16-2004, 01:25 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
Well mostly because RB26 = (RB25 pricex2) + (RB25 availablity/10)
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 10-24-2004, 12:58 PM
so what if id o try to weave a skyline exhaust which year/model would i use.
Old 10-24-2004, 02:10 PM
Z Cars Fanatic
what do you mean? all 90-96 300zx chasis are the same except for the 2+2 which would be longer. your probably not gonna be able to use the skyline exhaust with a 300zx. different lengths and bends. as for the z31's, they would probably be the easiest swap because in japan they came with a rb20det and converting that to an rb25 would be really practical.
Old 10-25-2004, 11:07 AM
1viadrft's Avatar
You are going to definately need to have an custom exhaust system made-up for you!
Closed Thread
