Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-11-2004, 10:00 PM
Sachse Sachse is offline
Engine surge on start
I've got a 93 Gt with a built 302. Here are some of the performance parts:
Tremec 3550 5 speed tranny
Trick Flow stage II Ports twisted wedge heads flow .311 intake side 2.02/1.60
Gt 40 Intake fully ported to heads Felpro 1262 gasket
Eagle H-beam rods
JE Pistons cut for the Trick flow heads
B-cam
1.6 Comp cams Pro magnum Roller rockers
75mm Bullet Pro-M mass air for 30lb
30lb motorsport injectors
70mm Edelbrock/BBK throttlebody
mac short tube headers
Mac off road h-pipe
2 chamber flows
Heres the problem. When I start the car up it will surge from 1000 to 1500 and it gradually stops surging into a normal idle.
A friend said it could be the computer adjusting to all of the performance parts and I may need a custom chip burned.
Has anyone had this problem or possibly know what it could be? I had the MAF re-calibrated and had the TB checked. Any help appreciated.
Old 10-11-2004, 10:49 PM
Mendari Mendari is offline
Re: Engine surge on start
I agree with your friend, your 5.0 is flowing at a much higher CFM than it did with the factory programming. It's either the factory programming or the Idle Air Control Valve is overly-eager. Have you reset the computer?
Old 10-12-2004, 02:34 PM
Yes, I've reset it a couple of times recently. It didnt get rid of the problem though.
Old 10-15-2004, 07:27 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
My car use to do that a lot, and I took a few steps that seemed to solve the problem.
-Made sure the TPS was set to .98 volts
-Cleaned the IAC as well as the MAF sensor
-Bought and air idle bypass plate, (goes between the TB and IAC)
-removed small vacuum cap on the vacuum T of the firewall. This got rid of an surging I had, put cap back on and it surges, take cap off and no surge.
-Then adjusted the idle to 800 rpms with the IAC unplugged and let idle for a few minutes before plugging back in.
-Dissconnect the battery for 20 minutes and reset the computer followin the reset method
That was just a brief description of what I did, hope it helped some.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 10-15-2004, 10:52 AM
thanks for the help, I'll have to try those methods out.
Old 10-17-2004, 11:58 AM
Re: Re: Engine surge on start
-Made sure the TPS was set to .98 volts ...
Using HiFlow's abundant knowledge as a platform, I found this site...
http://www.allfordmustangs.com/Detailed/581.shtml
It describes setting the TPS.
Hey HiFlow,
You should try to contact Jay Leno and see if he needs an on-site Automotive Engineer.
