Old 10-11-2004, 10:46 PM
Vankangas12 Vankangas12 is offline
Send a message via AIM to Vankangas12
Amp Stays on?
Im using my stock head unit and i have an amp and sub. I didnt use a remote wire, because it was messing the sound up. So I have the power wire going to both remote and battery terminals. Now it wont shut off, or if it does not for a long time. What should I do?
Old 10-11-2004, 10:52 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Amp Stays on?
The remote is what tells the amp to turn on, when the remote goes to 12V, the amp turns on. Since your remote is always at 12V your amp is always on.
You need to use the remote input for what it was designed for, run a remote wire to something that's switched with the ignition, I'm sure you can find a switched power source in the fuse box, and if not then tap into the wires going to you cigarette lighter (if yours turn on and off with the ignition that is).
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 10-11-2004, 11:47 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Amp Stays on?
Yes, sr2 said it exactally right. have a power antenna? Just a thought...
Old 10-12-2004, 04:50 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Amp Stays on?
or yo ucan go down to radioshack and get a little switch and run a wire and fuse it to like 4 amps and use it as your turn on switch. just a thought if yo udont wnat to fool with spliceing (though it isnt hard)...just throwing another idea out there.
