Old 10-11-2004, 09:28 PM
jt_crx jt_crx is offline
code 1 and ecu
i have 88 crx with b16a and pr3 ecu. my check engine light shows code 1. i replaced oxygen sensors, reset ecu and the code is still there. the light is on before i start the car. shoudn't it go off until i start it, i reset it and turn the key to the on position and the light is on throwin code 1.
is there anything else it could be? i also wanted to run new oxygen sensor wire. what kind would i use?
this light has been on for a long time and i dont know what to do.
the guy that did the swap said he tried different ecu's and that didnt help.
please help!!
Old 10-11-2004, 10:57 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Every time you turn the key to the on position, it will blonk once showing that the ecu has power. Does it blink repeatedly or just the one time?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 10-12-2004, 08:27 PM
Re: code 1 and ecu
please help!!
it blinks more than once. it blinks for code 1. but would the light stay on if i dont start the car.
Old 10-12-2004, 08:33 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: code 1 and ecu
I think your getting code 1 mixed up with the blinking of the ecu, it blinks every few seconds in a short burst. A code the blink will last alot longer.
Old 10-12-2004, 09:06 PM
Re: Re: code 1 and ecu
when i first turn the key it blinks once real fast then
it blinks once every few seconds, and the check engine light is on anyway.
Old 10-13-2004, 05:15 PM
check for a break in the wiring somewhere
ZC stuff
