Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 10-11-2004, 09:23 PM
goatnipples2002 goatnipples2002 is offline
cheap upgrades
I recently installed an MSD GM HEI coil in my car as well as the Rodney Dickman competion short throw shifter and the fiero store side scoop that says fiero on it. These are all less the $150 and very beneficial.
I noticed an increase in fuel economy and better accaeleration as well as better top end from the coil.
Before the shifter my 3rd would grind when I was racing but was cool when I was at low rpms, after the shifter install no grinding and about a 50% throw reducing and even shorter on the side to side.
The side scoop will only be decoration unless you pull the air box out, not fun. The side scoop is mainly for higher speeds when air will be forced in there, but I always drive at high speeds .
I am very happy with the results I have from the 3 products. The shifter and the coil are a must, but the coil over the shifter all day. the coil was 45.00 from advanced auto parts. List price is 79.00
Turbo 351w E85
Old 10-11-2004, 10:05 PM
Midnightryder Midnightryder is offline
Re: cheap upgrades
i was thinking about gettign the short shifter from the fierostore...when u get other stuff on it plz tell....if it is a good upgrade or not
Old 10-12-2004, 09:01 AM
FierceGT's Avatar
FierceGT FierceGT is offline
Send a message via MSN to FierceGT
Re: cheap upgrades
tell me the length that you want and i'll make you a short shifter
Old 10-12-2004, 09:14 AM
plz don't just shorten ur shifter that doesn't do anything except lower ur hand. Get the comp short THROW shifter from rodney. The fiero store's is $80 Rodney's is only $50.
Hell yeah anything that actually helps and is less then 50 bucks is a hell of an upgrade.
Turbo 351w E85
Old 10-12-2004, 05:09 PM
Re: cheap upgrades
hey goat how much did you pay for your borla and where did u order it from...???????
Old 10-12-2004, 06:28 PM
Re: cheap upgrades
wow i just checked the fierostore.com and they have the borla exhaust system..85-88 V6 BORLA CAT-BACK EXHAUST (W/ TIPS) for $599.00 did u get yours cheater...or is that where u got it?
Old 10-12-2004, 08:43 PM
Old Lar's Avatar
Old Lar Old Lar is offline
Re: cheap upgrades
Borlas from www.twinlakesfiero.com are less expensive that the Fiero Store.
Old 10-12-2004, 11:00 PM
Re: cheap upgrades
yeah i have been there...but i am looking for a price and they dont have one...i know i could call but i thought since goat might have gotten his from there he would know...it is not like i am geting it right now...but real soon future
Old 10-13-2004, 09:07 AM
I posted what I did in another thread.....http://www.automotiveforums.com/vbul...ight+reduction
Basically I ordered a Borla xr1 2.5 in/out oval racing muffler from summit, then had an exhaust shop custom bent a j pipe and tail pipe. My muffler hangs where the cat was. You can barely see the tip, it points down right before the e brake cable so the heat doesn't affect it. It sounds mean as hell. So when I say custom I don't mean I bought it from some guy who makes them, no I thought it out and had my original idea put to use. The only problem is finding people to work on it if you 86 your cat before you get the pipe bent. You should look at that other thread too.
Turbo 351w E85
