Old 10-11-2004, 10:13 PM
henrymv henrymv is offline
clunking noise in the suspension...
When I hot a pot hole pretty hard I get a clunking noise from underneath the car. If I run over the hole withthe front tires, the noise comes from the front end....and if I hit it with the rear tires, the noise comes from the rear area.....Any ideas???
Old 10-12-2004, 12:05 PM
AccordCodger AccordCodger is offline
Re: clunking noise in the suspension...
Well, you could stop running over pot holes!
Old 10-12-2004, 12:09 PM
No Sh** sherlock! LOL Guess you have never been on a Dallas surface road or highway!
Old 10-12-2004, 12:15 PM
Actually yeah - I have. (done worse than that, too -- the Brooklyn-Queens Expressway. Some of THOSE pot holes are bigger than an Accord!)
More seriously - suggestions - if the car is old, worn suspension front and back; exhaust system hitting the floor somewhere; supension bottoming-out.
Old 10-12-2004, 12:17 PM
Ok you got me beat b/c of the BQE...
i checked the exhaust...the donuts onthe muffler need to be repalced...howefer doesn't explain the front noise...have you had experience with stablizer bar bushings?? Yes this car has over 200K miles.
Old 10-12-2004, 01:33 PM
Bushings sound like a possible, but I haven't experienced your problem.
Old 10-12-2004, 02:34 PM
94accordVTEC 94accordVTEC is offline
Send a message via AIM to 94accordVTEC
Re: Re: clunking noise in the suspension...
hit a hole big enough any car will do this even brand new one's if it's doing it at all 4 corners it's not likely a problem just try not to hit them....however if you keep hitting them then it will start to wear stuff out
if you keep hitting holes you will eventually need these as well as other suspension parts
Old 10-12-2004, 02:39 PM
just to clarify before someone calls me out on it. I understand that his suspension is generally worn out as it has 200,000 miles on it and yes a new car would not do this as bad (but it would still do it) but what i'm saying is that there is not something broken most likely it is just normal wear and tear on the suspension and short of getting struts and all that i don't know how to improve the situation.
Old 10-12-2004, 02:51 PM
Igovert500's Avatar
blue + red light magnet
if the car is old, worn suspension front and back; supension bottoming-out.
Agreed and Agreed!...if it is a bouncy type of clunking your struts are most likely worn.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
