Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-11-2004, 07:18 PM
PowerCrazy PowerCrazy is offline
cylinder misfire
hey guys, know this might sound stupid but im not all that knowledgable on these cars.... I've got a '95 Tsi fwd, my "check engine" light just popped on this morning and ran the code on it and it said misfire in cylinder number two. HOWEVER, idle and low rpm's are a little rough but middle rpm's and freeway cruising feel/seem fine (haven't taken past 4 due to not knowing what the exact prob is). Just wondering if there is a common prob with this, i read something about the 2nd cylinder being prone to failing. Any input would be great, i'd rather avoid taking to a shop if i don't have to.....
oh yea, and which way do you count to find cyl #2
Old 10-11-2004, 09:26 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: cylinder misfire
A cylinder specific misfire is almost always ignition related. Try swapping the #2 plug with another cylinder and see if the problem follows the part. Do the same with the wire if necessary. Or just replace the plugs (gapped corectly) and/or wires and hope for the best.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
