Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-11-2004, 06:59 PM
B18c_all_da_way B18c_all_da_way is offline
valve float
can sumone tell me wut is valve float ??? plz
Old 10-12-2004, 02:47 AM
LSfrankie's Avatar
LSfrankie LSfrankie is offline
Banned
Re: valve float
At high RPMS the cam will push the valves down at extremely high speeds... If the spring is not stiff enough it wont pull the valve back up as fast as it should so the valve will "float" temporarily until the spring is able to pull it back up. It is bad because the piston can come back up and hit the valve and that = $$$$$$$$$$$. People will put in racing cams or even CTR or ITR cams and not change their valve springs and their chances of valve float are increased.
Old 10-12-2004, 12:55 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Re: valve float
thats the first reasonable thing ive heard from you. Valve float can also occur with F.I. The added pressure on the intake side from a turbo,sc,nitrous can be so much that the stock spring cannot pull the valve back up against the air current. This can happen at as low as 6psi
Old 10-12-2004, 11:33 PM
Re: Re: valve float
Recpect seen ,,much apprecaited,,,chick it man just be cool and yu'll last long in dis forum seen ,
Lex
Old 10-13-2004, 09:27 AM
EddieBrock EddieBrock is offline
Banned
Re: Re: Re: valve float
Lex
I'm just a newbie but, Respect/Recpect, check/chick, you'll/yu'll, this/dis, scene/seen.
Old 10-13-2004, 03:22 PM
GSfrankie GSfrankie is offline
Banned
Re: valve float
hahahaha. dont forget 6 commas in one sentence. does that mean a longer pause when reading it than usual?
Old 10-13-2004, 03:58 PM
Banned
Re: Re: valve float
I don't see how I missed that. Good job. Watch out though. These guys ban people regularly. Us newbies gotta stick together.
