Old 10-11-2004, 06:39 PM
winner1981 winner1981 is offline
Help opening the distributor cap
Hi! I wanted to open my distributor cap to have a look at it and the rotor (I have a 97 Civic DX). But looking from the front of the car, the cap opens to the left and there is this black box below the air intake. It does not leave any space for me to get my screw driver to take off the screws on the distributor cap. Can you tell me what that box is? It has 2 holes on the top and the air intake pipe has two small tubes passing into it. Is it safe to take this thing off?
Old 10-11-2004, 07:03 PM
dat1laosguy's Avatar
dat1laosguy dat1laosguy is offline
Re: Help opening the distributor cap
had you remove the airintake box yet?
damn i can barely see you in my rearview mirror
Old 10-11-2004, 07:54 PM
dy boun dy boun is offline
If you don't have room, just remove the stock air box and arm, that should give you room to get to the cap, then use a 8mm wrench not a screw driver to take off the cap, you might strip to screw.
Old 10-12-2004, 10:41 AM
Geeko Geeko is offline
Send a message via ICQ to Geeko
yes, you need to remove the resonator (air box) in order to get at the distributor cap. there are two 10mm bolts- one on top of the strut housing, the other behind the headlamp assembly. there may also be a plastic piece that is mounted to one of the radiator rubber bushing mounts- just pull on the air box, and it should come off.
a note of caution- be VERY careful when screwing the distributer cap bolts back in. don't use a ratchet, use a hand-nutdriver or just the socket with an extension to thread them in. i crossthreaded and broke the head off of one side on mine, and now i've only got one bolt holding it on. :/
BD (Before Deer): Clean... Very Clean.
AD (After Deer): Nascar Ready.
Go Baby Go.
Old 10-12-2004, 01:55 PM
-spiderman- -spiderman- is offline
Banned
Empty pockets racing, can I join the eastern division?
Old 10-12-2004, 02:13 PM
Beastiek2's Avatar
Beastiek2 Beastiek2 is offline
Banned
Send a message via AIM to Beastiek2 Send a message via MSN to Beastiek2
^^ ask GSCIVIC7
I think i'm member number 4 eastern division HOLLA.
Old 10-12-2004, 04:11 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Re: Help opening the distributor cap
you are #6 eastern division
and Beastie, you need to update ur sig meng. Where's the representation???
BTW: you're #5 eastern division
Empty Pockets Racing Member #1
Old 10-12-2004, 04:21 PM
Beastiek2's Avatar
Banned
Representing !! When we have a meet it will be global lol.
