Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 10-11-2004, 05:35 PM
bperazich bperazich is offline
OBD-II on 95-Jetta
Hi All -
I posted a week ago a note about reading the Check-Engine-Lights codes on my 95 Jetta. I was given the advice to go get a OBD-II reader and to get the codes.
I was able to get the OBD-II from AutoZone (here in California, AutoZone will not read the codes for you, but they *will* loan you the hardware to do it yourself).
Tries it out, and it didn't work --> "unable to connect". Ugh.
That having been said, after trying to connect for ~2-minutes, and right before "failing", the check-engine light did flash "3-3-3".
I was told that the 95-Jetta *may not* work with OBD-II. Is that right?
Does anyone know what "3-3-3" means?
Thanks ...
later,
-Branko.
Old 10-12-2004, 02:01 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: OBD-II on 95-Jetta
Look under the hood. If it is a late year model, it MIGHT be OBD-II. Chances are it's OBD-I.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-12-2004, 03:38 PM
yeah, i checked last night ... OBD-I. Ugh.
Also, connecting pin-4 to pin-15 didn't work for me. I read on another message board that the later-model 95's don't work with this mickey-mouse method.
Apparetnly, the only way I'm gonna get these codes is a) take it ot the shop, or b) buy the VAG-COM interface.
Does anyone know of any other way to read the codes?
Old 10-12-2004, 06:58 PM
boschmann boschmann is offline
Those are your options.
Old 08-15-2007, 12:35 AM
chasbo7 chasbo7 is offline
the obd-II DOES NOT WORK ON 95 THEY ON WORK ON 96 AND UP YOU NEED OBD-I THEY DO MAKE A OBD-II THAT WILL WORK IT HAS A ADAPTOR BUT IT COST ABOUT 200 DOLLARS THAT IF YOU THINK IT WORTH IT
Old 08-15-2007, 12:38 AM
I Have A 98 Jetta Is The Camshaft Position Sensor Located In The Camshaft It Self (where Is It Located Thank You ) can someone tell me please
Old 08-15-2007, 12:18 PM
bgalinec bgalinec is offline
Originally Posted by bperazich
Hi All -
Thanks ...
later,
-Branko.
Branko ako ti je auto 95 godina onda ti treba obd 1
Old 08-16-2007, 03:44 PM
i have a 98 jetta gt i would like to know where is the camshaft position sensor is located is it in the camshaft it self thank you. chasbo7
Old 08-27-2007, 01:46 AM
daglas daglas is offline
This also confused me. I have a 95' jetta and was told it was OBD-I. but I found the connector plug was OBD-II. Could I use OBD-II to check my car?
