Old 10-11-2004, 03:14 PM
98whitegpgt 98whitegpgt is offline
Send a message via AIM to 98whitegpgt
kr
i know this is a stupid question, and i should know this by now, but what is it, and how is it measured??? PS. im down to a 15.1 @89.44 mph im almost sure that i will hit 14s with my new pcm, either intense or dhp Look out stock gtp's here i come
Also where has ripin12s been, i havent seen any posts from him in a while
Old 10-11-2004, 03:29 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Easy way to explain is that when the engine gets any KR the PCM then retards the timming and to make any good HP, you dont want it to pull timming.
~Larry~
ClubGP Member 6530
Since 2001
Old 10-11-2004, 06:48 PM
AKWE-gt AKWE-gt is offline
Re: kr
the knock sensor is used to detect engine vibration(ie. spark knock or could even be from a worn engine mount) and sends the info to ecm. the ecm will retard the timing to solve the problem. with the engine running you can check it out by tapping the block with a hammer, next to knock sensor, and you should notice the engine kind of shudder for a second.
P.S. nice e.t time. looks like your getting your reaction time down or did you find a better way to launch.
[size=5]
Old 10-11-2004, 08:06 PM
Re: kr
can you give me detailed instructions on how to check how much knock i have?
i was getting consistant 2.13-2.17 60' on bald crappy delta tires. I was getting thoes launchs down good!!! I think im getting thoes new fusion zir tires, they look like a good tire for a very good price. My last few runs a guy i went down there w/ let me use this drags, and thoes kicked ass, almost no wheel spin at all!
Old 10-12-2004, 06:43 PM
Re: Re: kr
you would have to set up an aftermarket meter that can read kr. but in your case, even if you could read it, there's not much you could do to change it(reduce kr). you would could use it if you had a way to adjust the timing yourself, but this is done by the ecm. you would have more use for it if you had a stand alone ecm, which you could adjust spark timing or if you had a turbo and had adjustable boost, then you could read the meter to see how much boost you could safely run with.
here's a site where they used one on a RX7, but it's the same theory though.
http://www.scuderiaciriani.com/rx7/k...r_install.html
[size=5]
Old 10-12-2004, 06:55 PM
BIG-L's Avatar
Rocker arms and headers can help reduce KR,even colder plugs can reduce it a little.
Old 10-12-2004, 07:22 PM
Re: kr
higher octane umm.... gotta go the yankee/sox game started.
[size=5]
Old 10-12-2004, 08:18 PM
GTPCatz GTPCatz is offline
Banned
Re: kr
Good KR reading
http://www.stlclubgp.com/tech/kr/
http://www.zzperformance.com/zzp/info/mystery_kr.htm
Old 10-12-2004, 09:53 PM
Re: kr
thanks guys
