Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 10-11-2004, 03:04 PM
91redmr2turbo 91redmr2turbo is offline
Angry some problems
I have a 1991 mr2 turbo and I am having problems. 1st off my throttle sticks.2nd It idels rough sometimes and other times its fine. Lastly when I am driving around 2500 to 3000 rpm then I press the gas down my rpm go up slowly the backend shakes and there is this weird knocking noise. Can you guys help me please!!! Thanks
Old 10-11-2004, 06:27 PM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: some problems
What mods do you have?
I would start with the basics:
Toyota cap/rotor/wires new air filter and new fuel filter.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 10-11-2004, 09:30 PM
i have an apexi intake greddy exhaust and a greddy intercooler.Is it possible that the exhaust is the cause of the acceleration problem?
Old 10-12-2004, 07:41 AM
AF - Advisor
Re: some problems
Your exhaust would not be causing any of that.
I would check all of your IC pipes ... make sure you do not have a leak somewhere. With the engine jumping around, it is common to pull an IC hose enough that it leaks.
What about your ignition pieces as I mentioned?
What date is painted on your wires?
Old 10-12-2004, 09:59 AM
BlitzKeg's Avatar
BlitzKeg BlitzKeg is offline
A clogged cat can cause acceleration problems.
They get clogged due to excessivly rich a/f mix, miss fires and any unburnt fuel reaching your cat.
I'd check the cat just in case.
Old 10-12-2004, 10:04 AM
AF - Advisor
Re: some problems
Good point BlitzKeg I forgot a lot of people hav cats. Hie GReddy exhaust would have eliminated the 2nd catr, but if he still has the OEM turbo he probably still has the primary cat in place.
Old 10-12-2004, 03:26 PM
Re: some problems
I can't even get the date off the wires.So I should check the cat.Check the ic and get Toyota cap/rotor/wires new air filter and new fuel filter. Do you think that is all it could possible be? Because one day I drove to work and it was fine and then as I left work it started to happen.
Old 10-12-2004, 09:14 PM
AF - Advisor
Re: some problems
If it were me, I would:
1st check the IC hoses ~ that's free
2nd I would get new TOYOTA cap, rotor and wires and some NGK copper plugs (#6097) and see what happens there ... since you need these regular maintenance items anyway.
3. See where that gets you
Old 10-13-2004, 05:57 AM
Re: some problems
ok thanks ill keep posting
